super 99 or 6870 or newest xona
E98, 2150's, 910hp, pressures was 4 psi higher @ 47psi, my bad, but injector duty was low 90's. So yes it is very doable. The key is making sure your pressure at the rail is not dropping. This was with a fuel cell and fuelab external pump and regulator, 8an feed line. Pressure (boost + base) was rock steady even at max boost. FYI if your running the stock Evo fuel rail you need to drill it out just behind the AN adapter fitting.
https://www.evolutionm.net/forums/ev...tang-dyno.html
Look at post #13
43.5 base pressure, 830hp (mustang dyno), E85, duty cycle in the low 70's. Dual 044's.
If you need 8 injectors to make over 900hp your fuel pressure is dropping period.
Look at post #13
I-5 Evo
121
Oct 28, 2017 06:04 AM
5LEEPERISAH23I
Jan 15, 2016 06:18 AM
tscompusa
Oct 19, 2015 09:59 PM
