Wideband help
Old May 21, 2016 | 02:10 AM
ODUB's Avatar
Wideband help
I'm looking for a good wideband to use for tuning, and to datalog AFR, boost, etc. I was looking at AEM Failsafe, and Zeitronix, but there are a lot of options. Which Zeitronix model is comparable to the AEM Failsafe? Any recommendations out there?
Old May 22, 2016 | 11:53 AM
codgi's Avatar
Well a wideband will log just AFR if you want boost and "etc" you'd want a some kind of combination gauge . If you are sticking with stock ECU and ECUFlash then the AEM wideband is tested and true'd. I've had mine for nearly 10 years with no issues logging over that period.
Old May 22, 2016 | 12:58 PM
LetsGetThisDone's Avatar
I really like my Zeitronix. I used a jumper harness. And it's all wired directly into the ECU so I can log everything through the OBD2 port with tactrix/EvoScan.
Old May 23, 2016 | 07:47 AM
Evo8cy's Avatar
You can wire in any quality o2 sensor, either narrow or wideband one, on any ecu, as long as the ecu's hardware and software supports it, has the feature built it that is, otherwise you'll need to re-programme its e-prom. If you have a stock ecu the zeitronix is a good option. If you just need to monitor the afrs, a cheap good option is a bosch LSU 4.9 5 wire o2 sensor combined to either an innovate, aem, or prosport digital cluster gauge. Mount the sensor on the downpipe, somewhere in the middle of it, which is away enough from the turbine but not too far for the temp, density and pulses of the gasses to be altered at a degree which would give you a not so accurate reading.
Marios
Old May 30, 2016 | 09:42 PM
ODUB's Avatar
I was looking at the AEM Failsafe, and the new AEM X-Series Wideband. Any thoughts?
Old May 30, 2016 | 10:09 PM
ODUB's Avatar
AEM X-Series with OBDII connectivity
Looking at this wideband. What do I need to log boost? A 4 bar MAP sensor and ECU tweak?
Old Jun 1, 2016 | 02:25 PM
nealeighc's Avatar
I have an innovate Mtx-l in my 9 and love it. Can't speak on the data logging. Came with software and necessary cables though
Old Jun 4, 2016 | 10:44 PM
codgi's Avatar
[QUOTE=ODUB;11622535]AEM X-Series with OBDII connectivity
From the documentation there it uses the CAN bus to get this info back. The X is the first Evo with CAN AFAIR so is this is for an older evo.......
Yes though depending on boost you should be able to get away with a 3 bar if you plan to run a max of 30psi ish.
Old Jun 5, 2016 | 08:08 PM
ODUB's Avatar
[QUOTE=codgi;11624541]
EVO IX MR. Yeah, I know I'm well under the psi limit, I was just saying that one in particular as in the only hardware I need is to upgrade the MAP sensor.
Old Jun 6, 2016 | 07:18 AM
kikiturbo's Avatar
wire a MAP sensor into the ECU... good for logging but much better for boost control... you need to tweak the rom to do that but there are instructions on tis forum... no more boost overshooting on spool up..
Old Jun 6, 2016 | 11:17 PM
codgi's Avatar
[QUOTE=ODUB;11624720]
Makes sense
On the USDM cars you swap the USDM sensor for the JDM/Evo X sensor. That's it. No need to wire an extra sensor in.
Seancj
Jul 19, 2015 06:31 AM
TitanMotorsport
Evo 'For Sale' Electronics / Lighting / Audio
Nov 5, 2012 01:52 PM
TitanMotorsport
Vendor Classifieds
Oct 5, 2012 12:38 PM
TitanMotorsport
Aug 31, 2012 11:44 AM
TitanMotorsport
Vendor Classifieds
