quick spooling turbo to make over 500whp
On the other hand you have a fp SS stainless steel.
V band o2 housing. External vband wastegate. Single scroll.
The mhi housings are not being made no longer. So you either buy used or send in your evo 9 turbo to fp and they can make it green.red.black. "mhi"
Oh. I operate in "relax mode" then. Even that scares the crap out of me at WOT. (you can tell I drive my car only a few hundred miles a year)
I'm with you. 25psi on any turbo I run. Conservative timing. I like to beat on my cars. LOL
It pretty much only sees track and AutoX, so not worried about it being faster around town.
A kill mode Red is a 600+whp turbo.
An HTZ green should be able to make 500whp on E85 no problemo.
Ahyone recommended a non-MHI turbo for 500whp is suggesting you spend more money than you need to.
You could get a 7163 with twin scroll and push it, but that's a $5,000 set up with manifold and all the extra bits.
Don't forget, Blouch makes turbos as well that use the MHI housing.
A good running built engine can make that around 30-32psi with e85 when the combination and tuning are good. I pulled it off with the ole HTA red MHI. HTZ should be easier. A number of people have run 40psi plus with the BB stuff but that can tax them over time.
Originally Posted by nemsin
Isn't it implied? I bet a stock turbo on race fuel and meth 'could' hit 500whp.
Originally Posted by kaj
Wasn't stated nor implied, no sir. Not sure I've ever seen a stock turbo do 500whp, though.
