New BW EFR Turbo Thread
Old Mar 6, 2017 | 10:43 AM
  #4381
awhit17's Avatar
Originally Posted by RS200
EFR knowers, how do IWG EFRs perform vs. EWGs? There is obviously a difference between dumped and re-routed wastegate setups, just wondering if IWG vs EWG makes a difference, too. The B2 frame has a 42mm wastegate, which is plenty big, but perhaps it creates extra backpressure that kills power?
Anyway, stumbled across this: http://www.8thcivic.com/forums/vittu...s-buy-iwg.html
I don't understand how a larger A/R housing with external gate can outspool the IWG housing, but I'm not placing too much faith in that "test".
I have a IWG 7670 and I'm starting to think it may be a bit underwhelming on a 2.0L.
I am familiar with the EFRs on both platforms. I had a 7670 on my 8th Gen, and now have a 7163 on my Evo 9.
The IWGs work very well on Evos, where you can set a high base pressure and do not need to run low boost for traction in lower gears.
On FWD platforms with high VE motors like the K series, the IWGs are at a disadvantage since you cannot preload the wastegate actuators a lot. The need to run lower boost in lower gears plus the high VE means it is hard to keep the WG from blowing open, which slows spool.
Old Mar 6, 2017 | 11:00 AM
  #4382
RS200's Avatar
Ah, good explanation, thank you. My 7670 came with the high boost canister, but I might swap it out for the Turbosmart 2-port. I see the 8th gen is using the Turbosmart, but yeah, 13 psi spring, with K20 VE, the IWG isn't going to like that. I was considering putting my EWG 7670 on my FA5, but sold it and bought an S2000 as a daily instead. Oops.
Old Mar 6, 2017 | 11:37 AM
  #4383
chetrickerman's Avatar
Veteran: Army
IMO, the IWG performs extremely well considering that it is a IWG. Obviously the EWG will outperform it, but for simplicity, IWG cant be beat
Old Mar 6, 2017 | 12:00 PM
  #4384
Benja258's Avatar
so 7163 or 7670 for 2.3 stroker
Old Mar 6, 2017 | 06:51 PM
  #4385
Veteran: Army
7163 with the 2.3L would be an absolute torque monster
Old Mar 6, 2017 | 06:56 PM
  #4386
RS200's Avatar
Yeah, that would be in the realm of this (STi 2.5L with 7163):
Old Mar 7, 2017 | 05:22 AM
  #4387
RalliartRsX's Avatar
So apart from the 4 port solenoid, no information is give in regards to which billet IWG, or the fact that they are running two different solenoids........
Purple plot is using an external WG housing from Treadstone using the VitTuned 4 port boost solenoid.
Green plot is using the BW IWG housing using the dual port billet actuator with a 4 port boost solenoid.
...........Or temp differences, tires, road conditions (or even on a dyno!!) or........well, I have zero information on if its a direct test, so in my eyes, that is not a good data point or test for that fact and comes off as very biased.......
Below is a good read on internal vs external. However, in the case of the BW EFR, the internal gates are designed VERY well and really do not lose much for either rthe B1 frame or the smaller B2 frame turbos
Internal-vs-External-Wastegates
Old Mar 16, 2017 | 05:34 AM
  #4388
Benja's Avatar
Originally Posted by MR ArcticC
Hi Benja,
Thanks for your dyno results. I haven't seen any 8374 IWG results on Evo.
Are the numbers WHP or at flywheel? And what fuel is it running?
Could you tell, how much back pressure there was vs boost in the highest hp run?
Numbers are at the wheels.
Fuel is 98RON and E85.
Just over 2:1 back pressure.
Old Mar 16, 2017 | 05:36 AM
  #4389
Benja's Avatar
Originally Posted by alpinaturbo
I am curious, why you stopped at 23psi? On Pump 93 Octane.
I would think that large frame turbo low backpressure would allow 25-27psi on pump with reasonable timing?
Unfortunately being a 'mid-mount' turbo setup, there are two sharp bends prior to the entry to the collector.
I believe that is the reason for the lower numbers on 98 octane.
Regardless of what I did with timing, boost, fuel etc, it wouldn't take any more reliably.
Old Mar 16, 2017 | 07:00 AM
  #4390
awhit17's Avatar
Just realized I did not share my end results in this thread.
Evo 9 (6 speed) on pump 93
- Stock Block/IM/TB
- Tomei Cams
- 7163 twin scroll
- Turbosmart single port 23psi actuator with ~4mm preload
- tuned at a flat 24.6psi boost target on AEM Infinity
We had multiple pulls at 447-451 to back up the numbers. There is some more in it on pump, but I wanted to keep the boost flat and tq at ~380. All runs in 3rd gear.
, on Flickr
, on Flickr
Old Mar 16, 2017 | 11:46 AM
  #4391
alpinaturbo's Avatar
May I ask you what Tomei cams specifically do you use?
Many of us really like Tomei, but tend to gravitate to GSC S2 as sort of a proven solution that leaves nothing on the table for our general goals of making peek power between 7400 and 8000rpm, and redline from 7500 to 8500rpm, depending on individual project.
But Tomei have always been toe-to-toe, and we sort of see them as connoisseurs choices in that Tomei offers a few 'in between' grinds..not just S1 and S2. But without testing its hard to tell which is optimal...So courious what you are using?
Old Mar 16, 2017 | 06:53 PM
  #4392
awhit17's Avatar
I am using the Poncam Type-Rs. I gravitated to these because I wanted to not go too big on the cam and lose transient response or boost threshold (I know that the S2s don't really lose out on the latter) but with a IX I could use a larger cam than if I had an 8.
The effective duration of the Type-Rs is more than the S1 but a little under the S2. It is almost the same as the Procam 270s, but with my stock head I did not see the need for 11.5mm of lift.
I was minutes away from buying a set of Jun 264s but could not find a cam card and did not want to buy based solely on word of mouth. I still want to try them though.
Old Mar 17, 2017 | 07:00 AM
  #4393
bsh's Avatar
bsh
Hi Benja,
You can see some dyno chart here post #7 from my 8374 IWG single scroll Evo 2 E85. Hp are @hubs Dynapack 6042:
https://www.evolutionm.net/forums/ev...l#post11225286
Old May 8, 2017 | 06:06 AM
  #4394
Wheelyking 9GT's Avatar
2.3ltr 7163 IWG ctec bottom mount manifold (kept air con) Magnus inlet - kelford 264 cams - link G4+ - shell v power 99 ron:-
Old May 8, 2017 | 06:13 AM
  #4395
7064 EWG is on now with same specification same fuel. Makes more 30ftlb more torque and 20 bhp more power than the 7163 IWG does at 1.65 bar. Will have graph overlay once finished power runs. Wastegates were blowing open at 1.75 bar so higher rated springs req'd.
Word is that switching to kelford 272 cams with 7064 can grab an extra 30hp too.
