New BW EFR Turbo Thread
Old Aug 17, 2016 | 07:47 PM
  #4321
mrfred's Avatar
Originally Posted by Brianawd
Skunk 2. The crack was most likely caused by me. When it first started leaking I thought it was just lose from when I installed the new injectors so I tightened it up.
When what was really wrong is the oring was bad. No worries found a new one for $100 online. So all fixed now.
Thanks.
Old Aug 18, 2016 | 12:50 AM
  #4322
Mick_O's Avatar
Heres my mates R33 GTR with an RB30/26 motor with an 8374 1.05 rear. Car is an absolute monster to drive. Boost is currently capped as the road rage gauge didnt work so no idea of shaft speeds. Most a car has done on this dyno with an 8374 is 480kw here in Straya 😉
Old Aug 18, 2016 | 05:21 AM
  #4323
RalliartRsX's Avatar
Did not go well. Got to packwood around 9:30am. Unloaded the car. Smelled e85 found a leak at the fuel rail. Thought I car it fixed but when I was siting in grid it started leaking again. So pulled the car out and found a crack in the fuel rail. Loaded car back on trailer and started drinking. Car is fixed now but no autocross tell September. R-comp for sure next year
That's very unfortunate! However, the upside is the car did not go up in flames, so there is that
P.S September is only a few weeks away so mind you!
Old Aug 19, 2016 | 10:56 AM
  #4324
efrevo's Avatar
fullrace posted new twin scroll evo 7163 dynochart at inssta gram,573tq 515hp, engine flywheel
Old Aug 19, 2016 | 11:03 AM
  #4325
alpinaturbo's Avatar
Is this stroker?
Old Aug 22, 2016 | 06:49 AM
  #4326
efrevo's Avatar
I sorry alpina do not know. RS motoring onelap circuit america evo9 is stroker 2.3 with the 7163 here
Old Aug 26, 2016 | 12:54 PM
  #4327
nemsin's Avatar
Originally Posted by awhit17
Update on 7163 downpipe fitment with the Full-Race manifold. This is a 3" CLR mandrel, fitment is good but close lol
Untitled by Alex Whitacre, on Flickr
Still no dyno results awhit17?
Old Aug 27, 2016 | 05:42 AM
  #4328
awhit17's Avatar
[QUOTE=nemsin;11656911]Still no dyno results awhit17?[/QUOTE
Not yet. I'll post a thread when the car goes on the dyno. Will be hopefully by the end of September.
Old Aug 28, 2016 | 03:14 PM
  #4329
uvambo's Avatar
Still the same Evo 9 with 2.4 and R2 cams.
This is the 9174 thats been on the car for over a year now. Look at that power under the graph! And holding 750hp for nearly 2500rpm. This was 39psi spike
tapering to 37psi.
Old Aug 28, 2016 | 03:51 PM
  #4330
Damn! 500 ft lbs from 4900 to 8200 RPM! Honking mid range on that thing!
Old Oct 1, 2016 | 05:05 AM
  #4331
awhit17's Avatar
Update! We got my car sealed up and running, but it had a weird miss at idle. Turns out the belt tensioner went bad and the timing jumped a couple teeth. Good news is no damage and a tune is going to happen the next weekend my tuner is free.
Bonus Pic: My complete Origin Fabrication downpipe + testpipe. 6.2 pounds!!
Old Oct 1, 2016 | 08:45 AM
  #4332
mrfred's Avatar
Glad you found the belt tensioner issue. That would have eventually been doom.
Old Oct 1, 2016 | 09:03 AM
  #4333
Benja258's Avatar
Originally Posted by efrevo
look at world time attack champions. EFR turbos on evo. Japanese teams shops see this, they use EFR now.
these shops you listed are all drag racers. they sell precision, fp, garrett,, of course they do not use these
can you post some links for those japs shop..?
Old Oct 1, 2016 | 11:14 AM
  #4334
Akorallygood's Avatar
Pte all day
Old Oct 1, 2016 | 11:23 AM
  #4335
awhit17's Avatar
Yep. I was crazy lucky it didn't let go on the dyno. I'll take it.
