New BW EFR Turbo Thread
Old Aug 12, 2016 | 03:50 PM
  #4306
nemsin's Avatar
My old IX's "street" 92oct tune spiked to ~26psi then tapered down to ~22psi near redline. Pretty sure that is how most tuners do it.
Old Aug 14, 2016 | 03:07 PM
  #4307
Talonboost's Avatar
Originally Posted by Brianawd
On the 7163 it did not want to go much past 27. Aaron had to put a
Lot of duty cycle in the boost control setting to get it to maintain 27psi.
Curious to know about your boost controller. Could you describe it a little?
Does it simply put out a pre-set constant duty cycle?
Or does it have a boost target map?
For example on my car (1990 Talon), which was also done by English Racing, we used the ECMtuning system which gives you a boost target map, like this: http://dsmlink.com/wiki/bcsoverview
With a system like this you could get a pretty flat boost curve if you want it, or shape it some other way if you want.
But we couldn't use that because we were doing a flex-fuel build, which cuts out the option for boost control by ecu.
So we wound up with an AEM Tru-Boost, which, all it can do is give you a couple of duty cycle pre-sets (plus a "crack pressure" setting). And that usually results in a non-flat boost curve. (Your boost curve I would consider to be pretty "flat").
Old Aug 16, 2016 | 06:41 AM
  #4308
efrevo's Avatar
It's a 60lb/min with only a 64trim exhaust wheel.
It spools almost the same as my 30r that is a 52lb/min with a 76trim
Exhaust wheel that was on a 2.0. Vs the 7163 that is on a 2.3l
Bro, you are measureing wrong things. nobody cares what is trim for exhaust wheels. You measure compressor wheel outer diameter. 7163 = 71mm. this is smaller turbo than hks, garrett gt30R. and you making 550hp. Now you say you need more power. but you, bought the too small turbo
Originally Posted by Construct
A perfectly flat boost curve from spoolup to redline usually means that the turbo could deliver more air (thus more pressure) at the lower RPMs, or that the turbo is being spun outside of its efficiency range at the upper RPMs. Usually the truth is somewhere in between, but fortunately it's not too difficult to install a shaft speed sensor on these EFR turbos to get some actual measurements either way.
As much as people like to chase the flat boost curve on these forums, it's usually not the optimal way to run a turbo.
Thanks you constructs is very good and correct post. people go on internet and think you need the flat boost, is stupid. I learnt that you need flat turbo speed, to get maximum from turbo. this means speed sensor and not flat boosts...
Old Aug 17, 2016 | 03:09 AM
  #4309
evo8vz's Avatar
hate efr on evos turbo sure they spool quickly but the top end sucks.
this is why almost no big traditional shop run these
dont see er,buschur,ag,ams and ect running these.
Old Aug 17, 2016 | 04:49 AM
  #4310
kikiturbo's Avatar
shops you mentioned run mostly 1/4, 1/2, and one mile races... no need for spool monsters there..
on the other hand, fastest time attack evo runs EFR..
havign said that, for race purposes the spool and transient response of EFR is not the most important, since high $$$ cars will run antilag anyhow.. and then you should probably go for garret tr30r turbo..
Old Aug 17, 2016 | 10:49 AM
  #4311
efrevo's Avatar
Originally Posted by evo8vz
hate efr on evos turbo sure they spool quickly but the top end sucks. this is why almost no big traditional shop run these dont see er,buschur,ag,ams and ect running these.
look at world time attack champions. EFR turbos on evo. Japanese teams shops see this, they use EFR now.
these shops you listed are all drag racers. they sell precision, fp, garrett,, of course they do not use these
Old Aug 17, 2016 | 03:18 PM
  #4312
Tonba's Avatar
You guys make very good points.
Generally Speaking
The fastest Time Attack / Circuit / Hillclimb setups tend to use EFR turbochargers. Sure the power might not be quite as much as Precision or Garrett, but response is much much better.
Drag races tend to use Precision or Garrett (inc variations) due to cost and outright power.
I guess it all depends on what you're trying to setup for car for.. IMO - if your trying to do everything well, just get the EFR.
Old Aug 17, 2016 | 03:36 PM
  #4313
Brianawd's Avatar
Bro
HKS is a 51lbs/min turbo
30R is a 52lbs/min turbo
The EFR 7163 is a 60lbs/min turbo.
Exducers size is not every thing.
Old Aug 17, 2016 | 03:38 PM
  #4314
RalliartRsX's Avatar
Brainawd, how did the weekend go?? I have a feeling that either
a) You have had zero time to post
b) It didn't go well
c) You bought some R-comps and peeled man hole covers from the tarmac!
Old Aug 17, 2016 | 03:49 PM
  #4315
evo8vz's Avatar
honestly doubt most people with evo will even do time attack. Most people do drag race or will have fun in Mexico some times.
FP or Blouch offer great stock frame turbo that will spool well and make 500 whp like an efr.
HTA Green, HKS 7640, Blouch 2.0 and ect will all see 25 psi around 3500-3800 rpm and will make 500 whp.
Old Aug 17, 2016 | 04:14 PM
  #4316
Brianawd's Avatar
Did not go well. Got to packwood around 9:30am. Unloaded the car. Smelled e85 found a leak at the fuel rail. Thought I car it fixed but when I was siting in grid it started leaking again. So pulled the car out and found a crack in the fuel rail. Loaded car back on trailer and started drinking. Car is fixed now but no autocross tell September. R-comp for sure next year
Old Aug 17, 2016 | 05:17 PM
  #4317
kikiturbo's Avatar
maybe in the US but over here we like cars that do well on the B road.. and can be hammered on the track.. so no dyno queen maps allowed..
also, when you talk about whp, take care which dyno you talk about as there is a great difference between DJ and mustang..
hks 7460 on the tune that I can use on the road and track, on EU 98 oct fuel (93 US) with cams will do 400 whp DJ, give or take, and will do 25 psi at 3500 rpm in 3rd gear.. so no loading up on dyno.. It also has SUPERB transient response..
Great turbo yes, but lets not overhype the whp..
Old Aug 17, 2016 | 06:38 PM
  #4318
mrfred's Avatar
What brand of rail?
Old Aug 17, 2016 | 06:50 PM
  #4319
Brianawd's Avatar
Originally Posted by mrfred
What brand of rail?
Skunk 2. The crack was most likely caused by me. When it first started leaking I thought it was just lose from when I installed the new injectors so I tightened it up.
When what was really wrong is the oring was bad. No worries found a new one for $100 online. So all fixed now.
Old Aug 17, 2016 | 06:55 PM
  #4320
MrLith's Avatar
Bro
Yep - inducer often has more to do with the power potential, too... and if you look at inducers:
HKS = 52mm 49 trim
30R = 57mm 56 trim
7163 = 57mm 64 trim
