New BW EFR Turbo Thread
Old Jul 29, 2016 | 02:17 PM
  #4171
deeman101's Avatar
Originally Posted by R/TErnie
I've made 570whp with a T4 IWG 7163... just for reference.
Eric, just curious. On what platform and dyno was this?
Old Jul 30, 2016 | 07:37 AM
  #4172
R/TErnie's Avatar
2.0L 4 cylinder... Dynapack.
Old Jul 30, 2016 | 07:52 AM
  #4173
mrfred's Avatar
I'm pretty sure he was interested in knowing at least what brand of vehicle if not the model, but maybe you're not at liberty to say?? Seems reasonable to guess VW or Audi.
Old Jul 31, 2016 | 02:32 PM
  #4174
RSMike's Avatar
I still dont know why more people haven't tried the 7064 option yet.
The inducer size is much smaller than the 7163 resulting in quicker spool.
And it'll still make 500whp on kill mode.
But with STOCK like spool with the twin scroll.
That will likely be what i'm doing
Old Jul 31, 2016 | 03:29 PM
  #4175
nemsin's Avatar
I think the indycar & mixed flow marketing attracts everyone to the 7163. Personally, I would like to see an updated 7670.
Old Jul 31, 2016 | 07:13 PM
  #4176
RalliartRsX's Avatar
From what I understand the 7064 didn't perform quiet what BW would have liked. A TS 7163 for a 2 liter would be a better option. For outright all kill mode, the 7064 will probably eek out about 20-40 WHP over the 7163, but loses a fair amount of midrange and spool.
Old Jul 31, 2016 | 07:32 PM
  #4177
deeman101's Avatar
Thats what I was wondering, would be helpful to know the general efficiency, whether its DI or not, and awd vs fwd/rwd. Although from 2.0L I4 and Eric's day job plus the stout numbers I'm guessing golf R or something else using a similar engine.
Old Aug 1, 2016 | 07:38 AM
  #4178
awhit17's Avatar
According to Full-Race the 7163 does everything better than the 7064.
Old Aug 1, 2016 | 08:12 AM
  #4179
nemsin's Avatar
Except come in a T4 TS EWG configuration. But yes the 7163 basically obsoleted the 7064 and 7670.
Old Aug 1, 2016 | 08:16 AM
  #4180
Considering how well the stock EFR wastegate performs on the B1 frame turbos, it would have been counter productive for BW to produce a EWG turbine housing B1 frame 7163. In addition, I would much prefer a proper internal gate on an Evo due to space restrictions and simplicity reasons, especially if the internal gate performs just as well as the external setup
Old Aug 1, 2016 | 08:19 AM
  #4181
nemsin's Avatar
Originally Posted by RalliartRsX
... I would much prefer a proper internal gate on an Evo due to space restrictions and simplicity reasons, especially if the internal gate performs just as well as the external setup
Actually, the IWG 7163 is much harder to fit to an evo and an EWG EFR. And no the IWG does not perform as well as a proper EWG setup.
Old Aug 1, 2016 | 08:43 AM
  #4182
First point is a fair assessment due to the length of the turbo and how the wastegate is positioned
The second point I tend to disagree with. See below. A test done from FUll-Race. GT3582r-vs-efr-8374-undivided-t3s-back-back-dyno-k20-2889919/
See posted quote below. The EFR wastegates are exceptionally designed. The issue most people have is running the correct wastegate diaphragm. I had a litany of issues setting mine up until I just went straight to the hard canister. the turbosmart dual port is even better with a proper 3 port solenoid........or better yet, use the solenoid BW provides with each and every EFR! Settings are very close to the MAC solenoid everyone uses, so setting it up in the ECU is a breeze.
The diagram mentioned in the post is missing the correct link. However, a quick search on google will bring it up in a cache format you can view
Originally Posted by Full Race Geoff
That test compares the GT35R .82 a/r vs EFR 8374 .83 a/r - both singlescroll undivided T3. On paper, the GT35R is smaller with a 68mm turbine wheel and maxxes out around ~68lb/min whereas the larger EFR 8374 uses a 74mm turbine wheel and ~79lb/min compressor max flow. The interesting things to note are that the spool is very similar on the dyno, but on the street the owner of the car is amazed how much faster and smoother the 8374 transitions into boost. Also the 42mm internal wastegate has no difficulty controlling boost on a very high RPM and high-VE engine. The boost control is actually *better* than it was with the exernal wastegate and vent to atmosphere dumptube.
We may test a 7670 on this next for comparison. I expect it would have the same top end as the 35R, but much more low end. Ive been getting a lot of PM's asking us to test the 6262 and 6765 T3 .82
Quote:
This test compares the GT3582R .82 a/r (Purple line) vs EFR 8374 .83 a/r (Green line) 91 octane pump gas @ 15 psi.
The main objective was to compare spoolup and powerband between the two turbos, while ensuring the 42mm Internal WG does not creep. Test car belongs to Jun Masculino (Ikon671 on clubRSX)is an RSX-S, powered by a built K20 . K20 engines are notorious for uncontrollable boost, so in this case it's incredible to see the EFR controls boost *better* than the externally wastegated setup he previously used. High boost and race gas next week
Old Aug 1, 2016 | 08:53 AM
  #4183
nemsin's Avatar
We can agree to disagree on which is better, IWG or EWG. Not to mention the EWG turbine housings offer bigger turbine a/rs; 1.05 and 1.45 vs the .92 on the IWG housing.
Old Aug 1, 2016 | 08:54 AM
  #4184
efrevo's Avatar
awhite,, 7064 is excellent turbo and unique. you see its lower EMAP pressure, 0.92 AR. also has a ported shroud.
7163 is excellent turbo but 0.8 AR means me EMAPs and not ported shroud, is possible to do some surging
Old Aug 1, 2016 | 08:57 AM
  #4185
For the lower power/smaller AR stuff, the IWG performs just fine IMHO. But yes, having larger housing options in regards to the EWG stuff is great in itself and I understand the reasoning BW didn't provide an internal option for the bigger AR housings.
