New BW EFR Turbo Thread
Old Aug 2, 2016 | 09:41 AM
  #4216
RWD4G63's Avatar
Originally Posted by RalliartRsX
Thanks for singling me out with incorrect information........
Please go back and read my post again. I mentioned the Indy housing as an option to a question a gentleman posted about wanting an EWG option. I am not sure how you garnered from reading my post that is the single answer or did I ever compare it to a twin scroll.........
And good on you for denying actual data in regards to a TS housing vs a Single Scroll in regards to spool and area under the curve.......you are more than welcome to rebuke Physics and deny actual DATA if you so please on your own terms . I mean shoot, the gentleman that responded to your post (which you entirely ignored) had actual data AND dyno graphs to prove the TS actually producing more area under the curve as opposed to the same single scroll option lol! Oh the irony......
Really? Where do you see me denying any data? You were responding to a guy who made a statement about wanting an external gate divided T4 housing. Sorry I didn't get your garbled post, but people (more than just you) were talking about wanting the 7163 in a larger T4 divided housing and/or an external gate T4 divided housing. All I'm saying is that even if BW made such a housing, it would probably perform marginally better than the v-band or divided housings that are currently available.
Old Aug 2, 2016 | 09:43 AM
  #4217
Dallas J's Avatar
Veteran: Army
Originally Posted by mrfred
None the higher flow pumps available at that time, Aeromotive, DeatchWerks, W400 (non-E85 older) were able to provide any more fuel than a punched W255. This was on an otherwise 100% stock supply system including wiring. The issue is that the restriction from the fuel supply line causes so much additional pressure at the pump that the pressure relief valve in the pump activates. I think the new HP W450 (E85 version) could actually supply more fuel in a drop-in application. However, I think the amp draw would be enough to toast the fuel pump fuse and substantially heat up the factory wiring.
http://realstreetperformance.com/Fue...ison-Test.html
This is the pump data I was looking at when I changed out from the 255 to 340 knowing I'll never go over what I'm already at since power band is critical to me and 300tq @ low rpm. Has this been shown to be wrong or did it come out later than your investigations?
Old Aug 2, 2016 | 09:46 AM
  #4218
LetsGetThisDone's Avatar
That is the second synapse I've seen fail like that. Makes me not want to install the one I have.
Old Aug 2, 2016 | 09:59 AM
  #4219
RalliartRsX's Avatar
More power to you buddy
Old Aug 2, 2016 | 10:10 AM
  #4220
nemsin's Avatar
Better is ... wait for it... better.
BW offers a T4 twin scroll EWG for the 7064, 7670, 8374, and 9174. But for some reason decided not to offer it on the 7163
If you are going to drop $5K+ on a turbo kit, why sacrifice anything.
Old Aug 2, 2016 | 10:47 AM
  #4221
RWD4G63's Avatar
They don't offer it for any B1 frame turbo.
Buy the supercore and the internal gate housing minus canister, weld the gate shut, and run two external gates off the housing. That should reduce emap a bit and get it into the same range as the v-band housing at max effort. You'll also have maximum control of the gates and can use as many-a-port solenoid as you'd like.
I agree that it would be lovely if they offered us a smorgesboard of housing options, but I don't think the 7163 needs them IMHO.
Old Aug 2, 2016 | 10:50 AM
  #4222
mrfred's Avatar
No doubt the 340 has higher flow at reasonable pump back pressure levels. Its the combination of high boost (28+ psi) and high flow at peak rpm requirements where all the pumps tend to give the same result because the back pressure on the pumps exceed the relief valve opening pressure. At ~500 whp worth of E85, I was seeing 16 psi of additional pressure at the pump compared to at the rail. Total pressure at the pump was 84 psi. This would be at the 45 psi row in the Real Street table. According to that, the Aeromotive is a clear winner, but my own experiences showed no benefit. In fact, the Aeromotive was the worst. Now this was back in 2011, and maybe Aeromotive made some changes since then. Here are my test results:
https://www.evolutionm.net/forums/ve...mp-wiring.html
Old Aug 2, 2016 | 10:55 AM
  #4223
nemsin's Avatar
I am not a fan of welding shut the IWG (bye bye warranty).
I am kinda waiting to see if BW brings the quick spool valve housings to market http://www.evoxforums.com/forums/sho...d.php?t=273897
QSV 8374 would be amazing.
Old Aug 2, 2016 | 11:02 AM
  #4224
Dallas J's Avatar
Veteran: Army
Ahh, good info Mychailo. I know the Aeromotive is now a generation newer and specific to E85 but all I can tell is its mechanically better sealed and more suited to ethanol.
Old Aug 2, 2016 | 11:30 AM
  #4225
Brianawd's Avatar
So picked up a walbro 450. Going to put it in today. Then I'm heading back to the dyno
Friday. If need be, I can lower the base fuel pressure to keep the pump happy as
I have way more injector then I need with the 2150s. I know lowing base fuel pressure on e85 works when using large injectors. On my gvr4 I made 562/484 on a single 255 with a rewire and 1600cc injectors.
Old Aug 2, 2016 | 12:01 PM
  #4226
mrfred's Avatar
Did you hardwire the 450 to full-time full voltage?
Old Aug 2, 2016 | 01:58 PM
  #4227
R/TErnie's Avatar
BW QSV in production is a mythical unicorn. They made one for hype.
Old Aug 2, 2016 | 08:15 PM
  #4228
Brianawd's Avatar
I will be doing a rewire on the pump tomorrow using 10ga with a 30amp relay and 20amp fuse. I already have a fuel lab fpr so I don't have to worry about over running the fpr.
Old Aug 2, 2016 | 10:16 PM
  #4229
chetrickerman's Avatar
Veteran: Army
Yup, its not going to happen.
IMO, 2.4L + T4 TS 9174 = perfection
Old Aug 2, 2016 | 11:02 PM
  #4230
Benja258's Avatar
Wish those guys was make some of this for e8-9
http://www.boostresource.com
(Efr bolt on for evo x)
