20g/10.5 results!
Which 20g compressor wheel? There are probably a dozen that are 52.65/68mm. 20g is now just a form factor, not an actual product anymore. At one time all that existed was the MHI 20g for a truck (with TD06 turbine), but no one uses that wheel anymore. I ran the 11 blade GTX style for 20k and just switched to the EFR style 7+7 blade. The GTX style had an extended tip to 71mm and the EFR style has an extended tip to 73mm. I never run stock TD05 turbine, but instead use the 9 blade TD05 which provides more top end flow and spools just as fast.
- Inducer: 52.5 mm
- Exducer: 68 mm
- Height: 31.5 mm
- No. of Blades : 6/6
- Bottom Type: Super Back
Spools nice and good top end power tho I'm going to change out turbine housings for a td06. Td05 housing makes it surge pretty bad. Boost is basically on/off but there's quite a bit of surge.
I could probably do an antisurge housing and fix it, but I'd rather have the better top end flow with the td06.
I would go with the TD06SL2 9 blade turbine wheel. Going to a full blown TD06 is going to kill all of your spool. The 9 blade TD06SL2 flows more than enough for a 6+6 20G, and will keep your spool decent.
Also, I don't know what your using for boost control and I am only familiar with tuning the EBCS on the Evo X.... but you can tune out surge assuming your wastegate spring isn't too strong.
Yah I just shortened it, but the tdo6sl2r is the gittup I'm looking at.
Very nice numbers! And as stated above there’s about 15-20 different Billet 20G compressors. Looks like your 6 blade works perfect with your setup. I’d also recommend the 9 blade Td06sl2 if you ever plan to upgrade. Could get very close to 500hp
Got an 11blade installed already lol. No more top end loss. Tho it does surge pretty bad. Ordered an ebcs to fix that
EVO8LTW
16
Feb 26, 2007 08:44 PM
EVO8LTW
Sep 14, 2006 07:17 AM
Blue Evo 8
14
Mar 26, 2003 06:03 AM
