EVO 8 FP RED Flex Fuel E70
Old Apr 9, 2018 | 11:50 AM
gqcode's Avatar
Veteran: Air Force
Made 505 whp/405tq
Old Apr 9, 2018 | 01:17 PM
2006EvoIXer's Avatar
Did your fuel pump run out of flow? I think a Wally 450 is what you should be running.
Old Apr 9, 2018 | 02:41 PM
ctfpevoVIII's Avatar
Nice #’s man! Is this with twin scroll or newer SS housing?
Old Apr 9, 2018 | 02:44 PM
butte's Avatar
Nice numbers, man. I had very similar numbers with the same turbo and cams on my stock block before I had the shortbock built
Old Apr 9, 2018 | 02:49 PM
His signature shows SS.
Old Apr 9, 2018 | 03:23 PM
LetsGetThisDone's Avatar
Power curve looks like single scroll.
Surprised it made that much on a single walbro 255.
Old Apr 9, 2018 | 03:34 PM
LukasG's Avatar
Nasty setup man!
Old Apr 9, 2018 | 03:52 PM
gqcode's Avatar
Veteran: Air Force
Thanx guys, yes with the new SS housing it felt great. I couldn't believe the difference vs 93. I wish the pump had E85 to see the number but I'm happy with my tuner!
I rewire my 255 Walbro so it constantly get 14 volts and engine didn't go lean during the pull. They say single Walbro is good up to 550 hp
Old Apr 9, 2018 | 04:02 PM
I think your tuner dropped the boost 5500-7000 because your 255 could not support the demand at higher boost levels.
With a bigger fuel pump, you could get maybe another 30whp at around 6300rpm.
Old Apr 9, 2018 | 04:20 PM
That's on gasoline, and still a maybe depending on boost. When I first got my red, the walbro 255 was done at 26-27psi, 420whp.
Old Apr 9, 2018 | 04:32 PM
Did you have 1800cc injectors too? It's still surprising it made this much. I wonder what the AFR is 5000-7500 RPM
Old Apr 9, 2018 | 04:39 PM
Why is the weight set at 3743 pounds?
Old Apr 9, 2018 | 04:49 PM
Injector size doesn't really help a fuel pump flow more fuel...
Old Apr 9, 2018 | 04:59 PM
yeah I’m a dummy guess I should of read his sig and like letsgetthisdone pointed out about his curve , it is definitely ss see how it hits later.
Old Apr 9, 2018 | 05:03 PM
gqcode's Avatar
Veteran: Air Force
Peak boost was 31 psi and went down to 28 and then going up. but my AFR 11.5 to 12 at WOT
The tuner didn't lower the boost he tried to maintain as much boost. There were no count of knock
Next move I will change my injectors to 1300cc high Z, the low impedance made it hard to tune but not the greatest for street driving
