Evo 8: MHI HTZ Red, S1 Cams, E85
Old Feb 12, 2019 | 01:30 PM
Wicked_X's Avatar
There is absolutely no need for S3's on a stock engine. You're just shifting the power to the right. S2's are the biggest this setup really needs.
He said built engine, plus said he wants to rev to 8k.
still probably overkill for a red. But a lot of guys like Gary run S3s with smaller turbos and like them
Old Feb 12, 2019 | 01:39 PM
LetsGetThisDone's Avatar
Even if it's built. Only revving to 8k with S3's is a waste, you're needlessly shifting power to the right.
Old Feb 16, 2019 | 05:58 PM
MIL.SPEC Erik's Avatar
Originally Posted by desiromeo812
The turbosmart makes boost control a breeze compared to the Fp actuators and makes sure we don’t get spikes in the low end since.
Can you expound on this more? Thanks.
Old Mar 3, 2019 | 11:22 PM
desiromeo812's Avatar
Hi Erik,
i have always found the turbosmart wastegate actuators to have better control over boost. For example the FP 18psi or 22 psi will hit the target boost in midrange and then taper off.. i have found the turbosmart doesn’t do that as long as the turbo can keep up. Also it seems to react better downlow at spoolup so you don’t get the 1-2psi overshoot.
-Gary
Old Mar 13, 2019 | 11:24 AM
Evo_Jay's Avatar
^ I have found the exact opposite. FP actuator are the most stable for me. Turbosmart ones are good, but def not as good as the FP ones.
Old Mar 21, 2019 | 06:11 PM
Brandoboosts's Avatar
congratz on those numbers dude! nice to get on the dyno and see the hard work pay off
Old Mar 21, 2019 | 09:56 PM
Wicked_X's Avatar
Thanks man!
