Evo 8 boost / vacuum problems
Old May 17, 2024 | 11:17 AM
matildagunnar's Avatar
Started to get different reading on my boost gauge a few days ago. I’ve concluded that when the car is cold its boosting as it should.
when the engine bay is warmed up the car is at 0,5 bar at some pulls. And at -0,8 while cruising with no throttle engaged. Some pulls it goes up to 1,3 as it should then barely gets to 0,5 the next pull. Car behaves as normal…
anyone who’s had the same problems?
Old May 29, 2024 | 11:13 AM
WRC-LVR's Avatar
Boost leak check all lines and also the boost gauge if mechanical
Old Jun 7, 2024 | 08:06 PM
deylag's Avatar
Could be a damaged wastegate if you dont have a boost leak. I would check the wastegate and see how much psi is needed to open it.
Matthew Austen
Aug 22, 2017 07:19 AM
megamon21
Jun 8, 2008 09:53 AM
Akeem
Oct 1, 2005 10:57 PM
Blue Evo 8
36
Jul 11, 2005 07:16 PM
J8dailo
Apr 12, 2005 01:51 PM
