Buschur 2.4LR, FP Red E85 results
Old Dec 4, 2025 | 07:43 AM
High_PSI's Avatar
Maybe but a Twin scroll can flow better if done right as well. READ:
https://dsportmag.com/the-tech/twin-...-great-divide/
The Bottom Line
The overlap of exhaust valve events between sequentially firing cylinders reduces engine performance and boost response. Twin-scroll turbocharger systems can either completely eliminate or substantially reduce this overlap period. When this overlap period is reduced or eliminated, the engine experiences less pumping losses and a reduced intake charge dilution for increased performance and efficiency.
With the twin-scroll turbo system, the engine is also less sensitive to the ill effects of long-duration camshafts. A twin-scroll turbo system is simply a better mouse trap than a single-scroll. Having quicker torque delivery when the driver needs it not only increases performance, but it also adds fun. Be sure to stay tuned and subscribe as we plan to show how the A/R of the turbine section affects performance.
No you MAY need a better custome built Twin Scroll Exhaust maniold. A ported stock is fine but you may need a much larger SS Twin scroll simply for more volume. I would imagine a huge Single Scroll may make more PEAK power but at the cost of everything else.
Old Dec 6, 2025 | 10:04 PM
LetsGetThisDone's Avatar
Originally Posted by Gtimportfanatic
but doing the SS doesnt mean abandoning the stock style manifold. i went SS and its mainly because of doing EWG ... either or whether the stock frame turbo is SS or twin scroll, they'll both be faster responding than a t3 or bigger frame turbo i think.
Unfortunately, No. A vband g30-770 smokes a single scroll FP Red. I enjoyed this setup more than more than scroll red, which did hit 400wtq at 3900. But it was down 70whp at peak, and didnt pull past 7000 nearly as well. With modern turbo tech, stock frame stuff is pretty meh.
Old Dec 8, 2025 | 07:42 AM
High_PSI's Avatar
Very Nice, that Red is PumpGas and that G30-770 is on a 2.2 and race gas or flex fuel? Race gas makes a hug different. My FP BB Red made 400 FP's or Torque on Pump and almost 500WHP 29 PSI falling to 27 at Red Line.
Attachment 339933
Old Dec 10, 2025 | 10:20 PM
deylag's Avatar
Attachment 339933
What gen is the FP red that you are comparing to? I was thinking that the current gen Xona Red would be a better comparison to the current gen Garrett.
Old Dec 14, 2025 | 07:40 AM
That graph is the G30 on ACN91 and E85.
My car used to have a Xona red with the htz compressor. It did 445whp on pump gas and 600 on E85.
After driving the g30 I would never go back to stock frame stuff.
AWD Motorsports
Evo X Dyno Results
237
Mar 23, 2011 12:16 PM
ROGERV
Jan 2, 2011 09:09 AM
AcePitcher11
Nov 23, 2009 08:52 PM
GGevo921
Jul 27, 2009 05:28 PM
AcePitcher11
Mar 26, 2009 09:48 PM
