3" vs 3.5" exhaust debate
Old Nov 13, 2025 | 11:36 AM
GreekEvo9's Avatar
5 Year Member
I have been trying to find a actual discussion on is it worth going to a full 3.5" exhaust system. Seems like plenty of people are making great power with 3" exhausts. My only concern is the clearance is drastically reduced on a slightly lowered car.
Thoughts?
Old Nov 16, 2025 | 10:35 PM
tunermt's Avatar
i'd say in 90% of cases it is over kill.
Over 500WHP it's worth it if your trying to squeeze out everything you possibly can but using a 3" will not hold you back much and keep the sound level WAY down. (you'll see 20-30WHP removing a 3" exhaust/muffler on a 600HP+ turbo engine. IMO if you can expand the exhaust pipe smoothly (bigger by 10-20%) than the turbine housing outlet it will flow the best for given turbine/housing size.
Old Nov 22, 2025 | 01:19 PM
MasterNater's Avatar
Ben Lin from the Gears & Gasoline YouTube channel went from a 3" to 3.5" exhaust and gained about 40whp. It should be noted that the 3" system was using a high-flow cat, and the 3.5" was not. They talk about the dyno numbers at about 9:30 into the video.
Old Nov 23, 2025 | 09:12 PM
LetsGetThisDone's Avatar
The car makes a huge difference lol
Dont need 3.5 until over 800whp or so.
cbseven
43
Mar 29, 2012 02:01 AM
ta ace
May 16, 2011 07:25 PM
superfreak
Jul 30, 2008 08:05 PM
Sgt Blamo
Sep 22, 2006 05:43 AM
Jasil
Automotosports - Illinois
10
Dec 22, 2005 11:21 PM
