06 Evo Rs install surgestions
Old Jul 26, 2006 | 10:32 PM
spyderx's Avatar
Originally Posted by alloyic_rs
anyone stylin any 6.75 inch speakers? will those fit?
I think my comps are 6.5". I had to make a baffle to house the drivers so that it could be mounted to the front door cutouts. No biggie, just use thin board or mdf for the baffle...
Old Jul 26, 2006 | 10:40 PM
onesicklambo's Avatar
Originally Posted by spyderx
Get what you want but try a highend Eclipse headunit! It is the best, with such clarity.
Anyways, on my RS I have Eclipse 8xxx headunit mated to delphi XM tuner all connected to two separate amps, JL audio component speakers ( a MUST!!!) and 12" alpine sub.
Basic but cranks clean when you need that escape!
Install them yourself and enjoy the experience...
By meaning the HU has so much clarity..but your running off a 4ch? Does the deck have build in EQ/X-over/ HIpass low pass filters? Whats the voltage outputs on your "highend" eclipse?..thats what matters. Also watts per channel can mean nothing if your running a 4ch.
Also some poeple buy RS's because the soley want a track car..and will prob keep it striped and no system. Others might buy it becasue its the cheeper model yet still an evo..and would want to upgrade later. I would not suggest the factory headunit and oem speakers unless you are realllllly broke and need tunes BAD. Invest in something a little more higher quality that you can actually put to good use and has functions that can help you.
my .02
Old Jul 27, 2006 | 06:12 AM
spyderx's Avatar
It's the combination of good HU and its complementing parts that include decent component front speakers w/ crossovers and separate amps - Eclipse amp w/ 50wx4 average and jbl unit w/ 300wx2.
HU puts out 8v signal and also has its crossovers. Nothing fancy but pure and clean.
Old Jul 27, 2006 | 08:17 PM
Motive's Avatar
Pioneer 7800 is a good choice, nice options with an ok interface and 24 bit dac. Get the Premier version though for the better warranty. In my opinion the nicest looking head unit now for a reasonible price is the Premier 880prs.
Old Jul 27, 2006 | 08:21 PM
andyjd's Avatar
still need to know about speakers
Old Jul 27, 2006 | 10:08 PM
^ what speakers do you want to know about? I know the alpine TYPE-R, S, and X fit in the front doors.
Old Jul 28, 2006 | 04:44 AM
andyjd's Avatar
well your the one that said
Alpine Sps 171a 6.5" comp front types
Alpine SPS 17c2 6.5 coax rear types
Old Jul 28, 2006 | 05:57 PM
^those ones you quoted me say TYPE S. And I said type s fits.
Old Jul 28, 2006 | 07:27 PM
andyjd's Avatar
If i buy em and they dont fit I shall drive to Ca and insert them in you
Thanks
Andy
Old Jul 29, 2006 | 02:59 AM
housedj's Avatar
all 6.5's & 6.75's will fit but will require work as the stock speaker is a Euro-Din 7". my midbass had a mounting depth of 3" vs the stock 2 1/16" so when i put them in the door, the window wouldn't roll down! so i made a baffle out of MDF & then trimmed the inside of the door panel so it would go back on the door...
Old Aug 5, 2006 | 02:55 PM
andyjd's Avatar
slight change of direction
going with:
Alpine CDA9856 head unit and two pairs of Boston Acoustics SX65 speakers.
Andy
Old Aug 8, 2006 | 06:47 PM
andyjd's Avatar
Done, sounds ok as well!
Thanks to everyone fro the advice.
Andy
Old Aug 8, 2006 | 08:39 PM
1fastevo8's Avatar
that sounds good if i leave out the sub & amp
Will those speakers fit, crutchfield seems to think they wont!
If you end up getting the speakers, and they don't fit, make yourself a trim-ring set out of .25" mdf.... Simple, yet effective.
manolo2011
04-06 Lancer Ralliart How To Requests / Questions / Tips
11
Nov 4, 2019 05:47 PM
atomicapples
Sep 26, 2008 10:26 AM
laxhero2
Jul 12, 2007 04:15 AM
stockredevo
10
Mar 17, 2007 11:40 AM
evilevo22
12
Mar 8, 2007 05:37 PM
