2006 EVO RS deck install help!!
Hey! im planin to install a deck soon w/speakers. Just wondering if i need a wiring harness because it didnt come with a deck, speakers, or wires that run to the speaker locations. Thanks!
do you need a harness? technically no........but it will make things A LOT easier. i did a few RS around here, and they came pre-wired for speakers and a HU. It actually made it easier for me to do all the installs. if for some reason its not pre-wired. its still pretty easy.
Good luck
Yeah do a search here and you'll find the part number for the plugs that mate up with the factory wiring. You don't need to cut any wires to install a headunit and four speakers. You may have a slight challenge getting some quality speakers that line up with the existing holes in the rear deck, but the fronts should match up no problem with most applications.
Get 4 of these plugs from Circuit City MET728104 to connect your speakers. Labeled for Toyota. $10.99/each. They will prevent you from having to CUT INTO your factory wiring. Bueno Suerte
FS[Northeast]: Evo 8/9 Rear Speaker Deck Lid W/Wiper Hole *Cheap*
yellowevo82
27
Jul 2, 2017 04:52 AM
EJM
Sep 13, 2007 09:53 AM
LancerMarita
Apr 14, 2005 05:42 AM
SpecVSpeed
Jun 5, 2004 10:52 AM
