Air/Fuel Ratio on a 9?
Old Jan 15, 2007 | 02:50 PM
GraphanaticIXSE's Avatar
I did a search and didn't spot a tread for this, so sorry if this is a repeat. I have an AutoMeter Air/Fuel ratio gauge that I want to install on my 9, along with boost and oil pressure. I have what I think is an accurate ECU diagram and I need some help verifying the proper pin connection for this sensor. I am not installing a new sensor, even though I understand that the computer will process information too quickly for this gauge to comprehend, thus resulting in a sweeping motion on the gauge. I had this on my Corvette, and the only time that I really care for accuracy of this gauge is when the car is at full throttle. This worked great for the 'Vette and I hope it'll go well for this.
Thanks
Old Jan 15, 2007 | 03:03 PM
J8dailo's Avatar
lol i thought your air/fuel ratio was at 9:1...
Old Jan 15, 2007 | 03:12 PM
whitey4d's Avatar
Thanks
All that guage does is read ur stock o2 sensor. It is worthless as a tuning tool ans is just a blinking light show. the only thing it could be good for is diagnosis of a bad front o2 sensor. All ur have to do is find the front o2 wire pin. I dont know about EVOs but DSMs had a spade teminal by the passenger kick panel that was just an output for the o2. Perfect for the narrow band o2 sensors.
Old Jan 15, 2007 | 03:15 PM
whitey4d's Avatar
I woudl also like to *** that the swing of the o2 during idle and part throttle is normal and that at WOT the sensor will show a steady reading in hundreths of a volt. if that is notht ecause and the sensor sticks at idle of cruise then the sensor is bad or damaged.
Old Jan 15, 2007 | 03:18 PM
Thanks for the info, so far. I understand that the light show comment, however I don't want to spend $500+ on a diagnostic sensor. I'll check the o2 pin.
Old Jan 16, 2007 | 10:08 PM
binh's Avatar
You can get a AEM wideband online for like $250 and it will actually give you probably the most valuable information a gauge in an evo can give you.
Old Jan 17, 2007 | 07:35 AM
crasher's Avatar
its pin 71 its a white wire ill post an image of which one your supposed to tap into, this image was provided to me by someone on here asking the same question.
Old Jan 17, 2007 | 07:36 AM
crasher's Avatar
Old Jan 17, 2007 | 10:13 AM
Thanks guys... I found it last night.
