2-din, and relocation of HVAC
Old Mar 6, 2007 | 03:03 PM
rallykid's Avatar
Hey guys, I am in the middle of doing the conversion, and it seems that the HVAC cables are a bit too short when the controls are placed on the bottom. Any of you guys had this problem, how did you route the cables?
Old Mar 11, 2007 | 10:56 AM
EzNateZ's Avatar
You have to route them behind that module that's in front of the HVAC gears under the dash.
Old Mar 11, 2007 | 11:18 AM
04WWRS's Avatar
I just did this eariler this week. At first the bottom (black) seemed to short. I just tried moving it around and routing it different ways. Finally I got it. It barely went in the clip but is working fine.
Old Mar 11, 2007 | 06:24 PM
rallykid's Avatar
I shall give it a go once again.
Old Mar 14, 2007 | 12:37 PM
sorgar001's Avatar
Does anyone has pixs for this?? thanks
Old Mar 17, 2007 | 05:03 PM
RedAustinIX's Avatar
I had problems with this too when doing the 2-din install. One trick that might help is to twist the hvac knobs back and forth (this lengthens/shortens the cables) and may give you a bit play more to work with. You will probably need to temporarily put the knobs back on the white stubby things in order to turn them.
Good luck -- just have patience and you'll get there (seems like it took me forever but the end result was worth it )
RedAustinIX
polish_pounder
17
May 31, 2014 11:19 PM
Quicks916
Nov 22, 2012 01:45 AM
EVO.C
Feb 4, 2011 07:39 AM
rallykid
Aug 14, 2007 11:47 AM
