Alarm LED Placement?
Old May 24, 2007 | 04:50 AM
Dennis F's Avatar
Originally Posted by onesicklambo
BEST place is up on the center of the dash by the vents close to the windshield. This is the best place IMO because it is centered and can be seen from all angles. Also...the light is reflected right off the windshield and into the cabin of your car enhancing the light. Its just a little square part and can be poped off with a pick tool.. drill a little hole for the LED and wala! plus you wont even see it while driving.
Originally Posted by Dennis F
I put mine on the tiny square on the top of the dash just behind the windshield. It is kind of a pain just for the LED but the placement is awesome. It can be seen from anywhere around the car.
You will have to pull the radio and the plastic piece with the clock/hazard switch. Once that is out of the way, use a small pic tool and remove that square piece on the top of the dash, drill and mount the led and then just carefully snake the wires back to the brain.
This is exactly what I said allready
Old May 25, 2007 | 08:58 PM
onesicklambo's Avatar
^i was simply agreeing :P
BTW you dont have to take all that out (radio, dash, etc)..... Angle pick tool, be gentel, pop the square out, flush mount the LED, use a glow rod or a fishing wire with the led attached and run it down in the dash. Depending on where your brain will be located.... tho. cake
Old May 26, 2007 | 01:35 AM
NWEvoViii's Avatar
I must get a picture of where I got my alarm light installed. I think it will impress you guys. Pics will be up tomorrow. I might be the first one who has it installed in this particular place as well... We'll find out tomorrow.
Old May 26, 2007 | 09:13 AM
CasperGSR99's Avatar
i ended up putting it where dennis recommended using onesicklambos technique (found out for myself though haha) and it looks great. thanks for the help everyone
Old May 26, 2007 | 09:23 AM
SaOrlando's Avatar
i put mine in front of the clock above the hazard switch.
it faces toward the rear view mirror..... BUT i took off the lens cover so its clear.
you would never notice it was there unless you knew to look or it was on
Old May 26, 2007 | 09:43 AM
any hints?
The benifit of putting it where I said is that if need be, it is like a 2 dollar part to swap back in place if you remove the alarm. No one will ever now.
EXACTLY what i was thinking btw hahah
Old May 26, 2007 | 06:20 PM
NWEvoViii's Avatar
Here's the pics. IMO, I really like this spot, I think it's very unique.
Old May 27, 2007 | 07:21 PM
SaOrlando's Avatar
picture....
ignore the dust
the led actually reflects off of the clock, so its really noticeable when the its on
Old May 27, 2007 | 11:20 PM
IXmr321's Avatar
i dont have a picture of it because it was in my 1st evo, but i used two led's and mounted them in the corner of the vents on top of the dash board on both sides.....two made it really bright and obvious that you were protected
Griffin5
Dec 17, 2009 09:40 PM
Spish
15
Nov 14, 2009 06:44 PM
chaquita
Feb 9, 2009 12:07 AM
cheedo
10
Jan 4, 2009 05:09 PM
evo_shibby
10
Mar 7, 2007 07:17 PM
