Teaser pics, dual fiberglass Sub boxes
#76
#77
$1150 can you meet it or beat it?
http://www.sonicelectronix.com/item_...n+DNX8120.html
And more importantly, does it support A2DP for streaming bluetooth mp3s from my phone??????
#78
For tail lights, you don't need access from inside the trunk, you unscrew the tail lenses from the outside.
As for the filler :-)
The top hose runs to an opening in the front of the trunk, and has a cap on it. When not filling the trunk, the hose tucks into the side trim.
The side hose runs down and out the trunk vent.
To fill, you un-tuck the hose, and and pour fluid in through a funnel. Once the bottle is full, the overflow spills out the side hose and out from under the car. Re-cap the filler hose and tuck it back away
These were all mock-up pics... Everything was tightened and cleaned before the trim all went back together.
This is an excellent idea for those wanting to do the enclosure on the passenger side of the trunk. Good job on coming up with the design for the filler. Excellent.
I will be reffering people to these pictures if you don't mind.
Nazar
#79
k3lv
53
Jan 18, 2011 06:04 PM
12, az, box, boxes, construction, d6, diamond, dual, fiberglass, installation, portland, size, speaker, stereo, subwoofer
