e-brake wiring issue?
Old Oct 10, 2007 | 09:05 AM
EvoIXMR's Avatar
Before I go into details:
- I checked fluid level and it is good.
- I don't have an aftermarket front LSD (This is on a 04 SSL Evo with open diff)
Issue: When I drop the e-brake handle, the light dimmens slightly, but stays on.
I tried to see if it was the switch, but doesnt seem to be the issue. I even removed the switch and tried grounding wire seperately.
Only issue I can tell is that wire was broke when I got the car - I soldered it back on.
Are there any fuses for the e-brake? I didnt find any particular ones in the onboard glove box
I don't care about the e-brake and would eliminate the bulb, but I know it also displays low brake fluid which I would like to have for track use!
Any ideas?
Old Oct 10, 2007 | 09:18 AM
mifesto's Avatar
maybe ur solder job was poor. u sure the solder isnt touching both connection? maybe u have cold joints.
Old Oct 10, 2007 | 09:44 AM
EvoIXMR's Avatar
mifesto - Yes, I thought the same. So, I cut the solder off , stripped the wire and then even added some swire, twisted it on and then attached it to the switch - as well as removed switch and directly on to e-brake and still nothing.
Something is happening as it dims, but doesnt go out completely. Baffling me so far!
Old Oct 10, 2007 | 09:50 AM
mifesto's Avatar
honestly i havent touched that area since i havent had the reason to, but if i saw a 'dim' light i would first attack grounding issues. sory wish i can give u more suggestions... i'd have to study the shop book electronic diagram to see how the indictator is wired myself.
Old Oct 10, 2007 | 10:18 AM
EvoIXMR's Avatar
Yes, I was wondering if that wire wasnt grounding, per say to kill the display. Its a single wire which makes me wonder else it could need to work. If you do ever look into this, I'd love to know. Else, I may resort to removing the light and checking fluids after every event or inbetween events!
Old Oct 11, 2007 | 10:31 AM
EvoIXMR's Avatar
anyone else have any ideas?
Old Oct 11, 2007 | 11:44 AM
griceiv's Avatar
if dropping the ebrake has some effect on the light then i would say that the ebrake circuit isn't the problem. Check the fluid switch and make sure it and the wiring to it are good. As far as i know those are the only two inputs for that light.
Old Oct 11, 2007 | 11:46 AM
budlong's Avatar
check your brake pads. That light can come on when the pads are getting to small.
Old Oct 12, 2007 | 07:59 AM
EvoIXMR's Avatar
Thanks guys, I will check the pads as well - I assumed thin pads will cause low fluids, so I checked fluids, not pads!
Green_Bandit
21
Sep 9, 2019 02:14 PM
drucea
18
Oct 6, 2010 07:00 PM
ralliarv
Sep 3, 2009 01:01 PM
WillEatUrSTi
Mar 18, 2006 11:12 PM
lilevojoe
Oct 23, 2003 02:18 PM
