Turbo Timer Question for Clifford Matrix 50.5X
I can't seem to get my turbo timer to work. I followed the instructions according to the owner's manual but the engine shuts off when I close the door. Please help!
If the installer used the new 689M interface module or some other bypass method to ensure your car was in neutral before remote starting again, then I can see how that would be a problem for the built in turbo timer. I'm sure there is a way around it though.
My installer did put in a module to prevent car from remote starting in gear. How would that affect the turbo timer?
I would bring up your issue to the installer. There may be a way around it or he may have to remove the nss.
check your neutral safety switch wire, and make sure that they did not hook that up to your door trigger thinking it was the domelight wire. i bet you anything that is your problem. both wires are the same color, black with a white stripe, the little wire is neutral safety switch, and the bigger gauged wire is your domelight supervision
im willing to bet almost anything that is your problem!!!
~sarah
~sarah
FS[Northeast]: HKS Turbo Timer
Freddy302
Oct 11, 2016 05:55 PM
awdturbopsi
16
Mar 10, 2010 03:50 PM
veilside prius
10
Jan 6, 2008 12:19 PM
