OEM Keyless Entry Question
Old Nov 20, 2007 | 09:31 AM
shupadupa's Avatar
Question OEM Keyless Entry Question
Hey this may be an odd question or a over-asked question, but for about the last 5 months my horn no longer beeps when i lock the doors on my 2003 Evo. I am betting the battery in the clicker is dying which may drive the lack of the honk? The keyless still works fine, just no beep. And the horn still works perfectly in every other application.
Any thoughts EvoM, recommendations?
-Jon
Old Nov 20, 2007 | 09:37 AM
wizzo 8's Avatar
There is a procedure to turn it off or on. It says in the owners manual how to change it. Or you can call the dealer to find out how to do it. I personally forgot how to do it.
Old Nov 20, 2007 | 09:43 AM
shupadupa's Avatar
hmm thanks i will need to read the manual. I was wondering if it was the "Car" telling me that the remote's battery was getting low. I will see what the owners manual has to say though.
Old Nov 20, 2007 | 10:11 AM
NoTec's Avatar
Sounds like something is wrong with the keyless system in the car. How's the range on your remote?
Old Nov 20, 2007 | 10:29 AM
shupadupa's Avatar
I honestly think the range is week, and in all honesty the batteries are 4 years old at this point. If i swap batteries does it need to be "reprogrammed"? I am willing to be it does.
Old Nov 20, 2007 | 10:32 AM
BoostEEd's Avatar
No. The car is programmed to accknowledge that key FOB. Swapping batteries will change nothing. I seriously doubt that has anything to do with your horn not beeping as the key FOB doesn't tell the horn to beep or not, the keyless entry system does. I bet you dissabled it somehow or there is another issue, but I am willing to bet its not the battery.
Old Nov 20, 2007 | 10:34 AM
raiceboi697's Avatar
mine is doin the same thing, got new bateries and it worked fine, while i was at it i added some hella super horns, those things rock
Old Nov 20, 2007 | 10:41 AM
BoostEEd's Avatar
Really? Swapping batteries in the FOB made the horn beep again? I guess the keyless entry system is smarter than me.
Old Nov 20, 2007 | 01:51 PM
sna08's Avatar
It is normal, its a feature you can turn on or off when u lock the door to have it beep or not like wizzo8 said in the first post... my bro has the honk and I don't (I like to be more discreet) if I press it twice it'll honk... but the first press won't honk
Old Nov 20, 2007 | 01:52 PM
wizzo 8's Avatar
Thanks for backing me up SNA08
Old Nov 20, 2007 | 03:11 PM
sna08's Avatar
No problem, just want the right info on here....
Old Nov 20, 2007 | 04:33 PM
wizzo 8's Avatar
The only question now is how to do it
Old Nov 20, 2007 | 06:25 PM
Joeekrub's Avatar
owners manual
Old Nov 20, 2007 | 06:34 PM
wizzo 8's Avatar
Thats what I said but its not to clear
Old Nov 25, 2007 | 07:17 AM
shupadupa's Avatar
I must have deativated it. So i pulled out the owners manual and sure enough it works again.
Hold the "lock" button for 4-10 seconds and the press the "unlock" button during that time, releasing both buttons at the same time.
Lock (Press and Hold 4-10 seconds)
Unlock (Tap during the 4-10 seconds)
Release both Lock and Unlock after you "tap" unlock.
Done.
Thanks guys.
