Tweeter wiring confuses me.
Old Jun 19, 2008 | 09:22 PM
VRSF Tiago's Avatar
I'm in the process of installing an aftermarket head unit and there are 4 wires for the tweeters, but my head unit's harness only has connections for the 2 front and 2 rear speakers.
How would I go about connecting the two front tweeters that are mounted to the a-pillar?
Old Jun 20, 2008 | 06:57 AM
Hardware's Avatar
I'm just throwing this out there since no one replied. First off I already installed a Alpine X001 in my car and the wiring harness (not head unit, but harness between HU and vehicle) only had enough wires for 4 speakers (8 total wires). I never took the a-pillar apart, but it's possible there are stock wires running from the mids in the doors to the tweets in the a-pillar. My guess is they piggyback wires from the mids to the tweeters. I would probably avoid those extra wires unless you plan on doing something wild like components with separate crossovers.
biggie5252's Avatar
Just hook it up like you normally would. The tweeters and the speakers in the door both come off the front wiring.
Old Jun 20, 2008 | 06:59 AM
biggie5252's Avatar
Nevermind, I see you have an SSL system. Not sure about that. If you have all the adapters, then it should just be plug and play and you shouldn't have to do anything special to hook up the tweeters.
Old Jun 20, 2008 | 07:16 AM
VRSF Tiago's Avatar
No adapters, I'm not using the amp. The tweeters are wired as thier own speakers but for now I spliced them into each respective front speaker but I can't try it out until I get my small battery in so we'll see.
Old Jun 20, 2008 | 07:30 AM
biggie5252's Avatar
I see. yeah they should be wired with the door speakers then.
Old Aug 21, 2008 | 07:27 AM
hytek369's Avatar
MRs have 6 speakers. How many does SSL have?
Old Aug 21, 2008 | 08:42 AM
biggie5252's Avatar
SSL should also have 6 speakers.
Old Aug 21, 2008 | 09:08 AM
92gsxbaltimore's Avatar
You wire them with the front door speakers, just make sure you put in a filter
Old Aug 22, 2008 | 06:22 AM
igo4bmx's Avatar
exactly or you will blow the tweets out in no time.
Old Aug 22, 2008 | 07:30 AM
biggie5252's Avatar
If they're stock tweeters, they should already have filters.
Old Aug 22, 2008 | 07:49 AM
VRSF Tiago's Avatar
The confusion is the reason I just disconnected them.
I'm guessing they are already filtered but at the same time I think they are filtered at the amp, not at the tweeter.
I think I removed something that might appear to be a filter from the amp side of the wiring but I did because I thought it was aftermarket from the previous owners radio/sub installation.
Old Aug 22, 2008 | 09:38 AM
biggie5252's Avatar
It's possible that it's filtered at the amp, but it would probably be internal if it was. What did whatever you removed look like? How was it wired in?
I, however, doubt that it's filtered at the amp cuz non SSL evos have tweeters (mine does anyway) with no amp and they're filtered. Take a multimeter (ohm setting) and measure resistance across the tweeter wiring. If the resistance holds steady it doesn't have a filter, if it slowly changes, more than likely increases, then it does have a filter.
Old Aug 22, 2008 | 11:26 AM
VRSF Tiago's Avatar
Oh I didn't mean IN the amp but at the amp location.
It was a little box and to be honest I didn't know which wires were which when I disconnected it so I don't really remember how it was connected.
hexaggram
Feb 28, 2015 03:56 PM
sharpMR
Jan 4, 2013 05:32 AM
oftheheavens
Dec 1, 2010 03:40 PM
rebelzx
18
Oct 11, 2003 11:41 AM
bcustom152
13
Sep 17, 2002 07:26 AM
