Thoughts and Comments - New Audio Setup
I'm pretty sure with the upgraded alternator and the yellow top battery you won't need the capacitors. Other than that, looks like you have a really nice system going on. I would recommend sound deadening, at the very least, the front doors. The trunk would be a good idea too.
Also, if you're only running the 4.100 to the components up front you might think about using a PCX 2.150. It will give you enough power and I'm pretty sure is a bit cheaper than the 4.100.
Capacitors=waste of money. Not needed especially with the big-3 and bigger alt. Good list of components though.
