Reverse Switch
Old Feb 27, 2009 | 05:01 PM
M4Lki3r's Avatar
Veteran: Marine Corps
Reverse Switch
I just got finished installing a new head unit (Kenwood KVT-512) and everything works great except I need to attach a wire to the reverse sensor/switch. I'm going to assume that there is a line on the ECU that knows it's in reverse to switch on the reverse lights, but I can not find the correct pin/wire to tap into. Any help on this? Thanks.
Plus some eye candy of the install.
Old Feb 27, 2009 | 05:07 PM
idriveanevo's Avatar
i think its on the tranny... you gotta find the sensor for??? rear camera or what?
Old Feb 27, 2009 | 05:25 PM
M4Lki3r's Avatar
Yes, it's for backup/rear camera.
Old Feb 27, 2009 | 05:46 PM
unsungboxer's Avatar
its on top of the transmission. easiest way to get to it is to remove the battery and battery tray. ull see the switched screwed in with a 2wire plug. it is supplied +power on one wire, when the switch is engaged , the other wire will carry power to the reverse lights
good luck!
Old Feb 27, 2009 | 08:15 PM
biggie5252's Avatar
You can find it under the drivers side floor trim (the bundle of cable under the floor). Or you can go all the way back to the taillight.
aduke05
10
Apr 26, 2020 10:31 PM
Veronica
Mitsubishi TC-SST Discussion
Aug 9, 2015 02:09 PM
Ibrahim Nabil
Lancer How Tos / Installations
Jul 30, 2015 06:21 PM
zze86
Nov 1, 2005 01:01 PM
cky3396
Jul 31, 2003 07:56 PM
