HELP! running wires to front speakers?
Old Apr 2, 2009 | 09:33 AM
StealthaPsYcHo's Avatar
I've already searched a lot and couldnt find a lot on this topic, everyone seems to be saying they used a straightened clothes hanger to fish the wire through the door but how the hell? the wire loom is so tight together, are there any other suggestions i should know in order to get the wire through the door?
Old Apr 2, 2009 | 12:34 PM
D1no's Avatar
I did mine, but its a Ralliart. Just tape it up at the end of a coat hanger. I used packing tape. Make sure that the sharp point of the hanger doesnt snag any wires. Push it with one hand an press the boot with the other. You'll be able to guide the wire through this way. I used some wd40 to lube it up a bit. Just go sloooow. Take your time.
I think you can take that door boot off on one end to make it easier.
Old Apr 2, 2009 | 12:53 PM
lexat20's Avatar
Patience Danielson...
Coat hanger worked for me in minutes
Old Apr 2, 2009 | 03:57 PM
accident's Avatar
start on the inside of the cabin going towards the door. push the rubber boot into the door to make it a straighter shot and just fish it through slowly and make a small hole on the boot on the inside of the door. when you got the length you want pulled through push the boot back into place in the door. hope this helps.
Old Apr 2, 2009 | 04:14 PM
Xraycat's Avatar
You can also use a long zip tie if you have one available, its a little more forgiving than a coat hanger.....just need to take your time with either one.
UnholyMaggot
Jul 21, 2019 09:53 AM
Evolution8RS
Mar 20, 2009 09:36 AM
vtluu
15
Feb 7, 2008 09:40 PM
urbanknight
Jan 17, 2007 09:42 PM
Dirwolffncsu
Lancer Troubleshooting
Jan 6, 2005 08:23 AM
