Where is the rear wiper RELAY?
I figure its probably under the dash, but the little description diagram only mentions the fuses!!
My rear winshield wiper stopped working. I think its either the fuse or the relay. I believe I checked the right fuse and it was fine. Relay next. I doubt I am having the same electrical gremlins as others as there is no corosion and i have no other problems. They worked untill the other day.
Also, I dont have the user manual. Thanks Town and Country Mitsubishi!
What repair manual should I get? Haynes, Chilton, Helms?
Thanks!
Thanks!
have this same issue, will check that harness.
speaking off, anyone know how to properly test a rear wiper motor. Haven't been to comfortable with connecting directly to the battery like the manual says.
will try to upload images from manual today
i got mine working again. yey.
my dumb *** accidentally unpluged the small connector right under the rear wiper when i was putting a sub and box in the trunk. The connectors come undone easily. Its in the trunnk right under the wiper. dunno u guys could check that too!
But yeah that corrosion blocks current flow pretty good. Even if u scrape it off, it still causes terrible things!! My old for bronco has massive electrical problems do to corrosion. I have to consitently lay down lengths of wire to replace corroded wire that looks like its still good but really isnt.
unkSauce
Lancer Troubleshooting
Jul 19, 2016 10:30 AM
AWD96
14
Jun 17, 2014 02:47 PM
