Hids ruining radio signal
Old Oct 25, 2009 | 08:59 PM
rongdoer's Avatar
I put in a hid kit and now every time I turn my lights on the radio gets really fuzzy. It's an aftermarket stereo but, jeez I don't know what I could do.
Old Oct 25, 2009 | 11:18 PM
LuisIX's Avatar
check the ground on the amp...or try changing it up move it around..its a grounding problem...
Old Oct 26, 2009 | 05:06 AM
BlackMRSE's Avatar
+1
Or check your Grounds upfront by the actual lights. Did you install both at the same time or one after the other. Moreover, when did the problem occur? I am assuming you had the aftermarket stereo, everything was fine, installed the headlights; fuzz. If thats the case then I would say check your headlight(s) ground. It may seem odd, but in the end a bad ground can do funny things to your car. Friend of mine built a B16 in a civic, car wouldn't turn over b\c of a bad/ incorrect ground.
Lastly, and this would be the last thing I would think about, but just curious where did you get the HIDs? Used? did they come out of someone elses car? are you 100% they are in 100% working order?
Old Oct 26, 2009 | 09:33 AM
matt55's Avatar
Its a bad Balast(s) .
All ready been down that road !
Old Oct 26, 2009 | 09:39 AM
whitegalant's Avatar
Lol that's kind of a broad statement. That's like him asking why his car won't run (threw a rod and doesn't kno it yet). And u popping in and saying "your out of gas! Already been down that road!" lol
Old Oct 27, 2009 | 07:30 AM
eXtreme-Speed's Avatar
And what was the point of posting that? At least he gave some feedback.... What did you give nothing.. Fail
+1 to the ground though. Make sure your speaker wires are seperated from other wires. This might cause it to.. Just a thought though. Good Luck!
Old Oct 27, 2009 | 01:42 PM
matt55's Avatar
Like I said Ive all ready been down that road
https://www.evolutionm.net/forums/se...5-hid-kit.html
I left out the the hrs of phone calls to the seller / tracking / isolating /switching out ballast / bulbs / removing front end and trying a "fix" noise suppressors from the seller ...
I learned alot since my 13th post
Old Oct 28, 2009 | 11:27 AM
BlackMRSE's Avatar
Lol oddly enough I thought to actually recommend/ say it could be a ballast in my post a few back, just thought it would be jumping to conclusions too fast...
Old Oct 28, 2009 | 02:03 PM
matt55's Avatar
LOL
Wife tells me Iam not as smart as I think Iam , and I might be(Iam) wrong .
But he said he just put them in , from what Ive seen most new HID kits dont use the solenoid/wiring set but instead use a plug-n- play set up .
So it shouldnt be a ground seeing how it uses the stock wiring .
Soooooo I say the its the Ballest(s) and I did stay in a Holiday Inn last night
Old Oct 28, 2009 | 03:04 PM
BlackMRSE's Avatar
LOL
Yea tough to tell, OP left a few details out, and we haven't heard back from him since. My money is on something with the lights, like I said just a few details left out to really dive into it. Funny you had the same thing happen, in an ironic way.
Evoracing47
Sep 21, 2014 06:49 PM
Rall1boy
Apr 19, 2013 08:00 PM
JustJeff
Nov 3, 2012 05:55 PM
RA032924
May 5, 2009 09:56 AM
Tsurara
Dec 11, 2004 11:12 PM
