Power source for gauges
Old Nov 2, 2009 | 09:24 PM
brokenRS's Avatar
Where are you guy connecting your red(12v) and black(2a) wires? I have two xd-16 and they only gave me 7inches to work with, most likely i'll extend it out. I will have two xd-16's mounted on my steering column with an ATI dual pod. Any clean way to wire these suckers?
Old Nov 3, 2009 | 10:56 PM
brokenRS's Avatar
Nobody!?
Old Nov 4, 2009 | 05:30 AM
thedru13's Avatar
I ran constant power from my interior fuse panel under the steering column.
Old Nov 4, 2009 | 05:33 AM
Kracka's Avatar
I'm getting power from my steering column harness. Pop the plastic covers off and you'll see all the wires you need.
Old Nov 4, 2009 | 05:35 AM
Babs's Avatar
You can either fuse tap, which doesn't require much work, or you can t-tap into 12v wires.
I used both options....for my Innovate wideband, I t-tapped into the yellow 12-gauge power windows wire. For my Prosport boost gauge, I just fuse tapped (no special tap, I just tucked the exposed part of the wire under the fuse and plugged it in)
It's up to you...look in your manual for a list of 12v fuses that you can tap into.
EDIT: And isn't black the ground wire for you? If you're asking where to ground that, look on the side wall right next to the under-panel fuse box and you'll see 2 or 3 wires already grounded on a bolt in the wall. Unbolt that bolt and tuck in another wire or two and bolt it back in.
Old Nov 4, 2009 | 08:42 AM
2.4evo's Avatar
interior fuse panel will do the job,its what I used myself.
Old Nov 4, 2009 | 05:28 PM
brokenRS's Avatar
Thanks guy! Waiting for 3 more boxes to come in from mapperformance.
Old Jan 9, 2010 | 10:51 AM
guyver858's Avatar
I am going to be installing some gauges soon as well. I think I am going to go the fuse panel route and use a add-a-circuit.
Does anybody have a fuse panel diagram? what fuse is for what?
The service manual just says fuses Numbers 1-21.
Old Jan 9, 2010 | 11:27 AM
guyver858's Avatar
nm found it, its in the owners manual duh
Old Jan 28, 2010 | 04:20 PM
vetboss's Avatar
Originally Posted by eb66
ooo fuse tap sounds nice
SHould do you fine!
Good Luck
Old Jan 28, 2010 | 04:24 PM
19DB794's Avatar
I tapped power from my radio for my gauges. Mitsu wired the factory gauges the same way.
Old Feb 1, 2010 | 08:48 PM
djslik408's Avatar
you also need to consider that once you turn on your ignition, your gauges should also come on. I did this a few weeks ago and it was a quick install.
Old Feb 20, 2010 | 01:52 PM
timmycat's Avatar
i taped into the radio wire harness works fine for me
maxspeed96ct
Aug 22, 2016 03:59 PM
Sheasta
Dec 13, 2015 04:39 PM
Chino051
For Sale - Wheels / Tires
May 12, 2015 06:55 PM
Teal2nnr
Jun 10, 2014 06:35 PM
Dragracer187
Jul 23, 2008 01:46 AM
