anyone upgrade from 35w to 55w hid ballast?
dude, stock evo fogs are indeed 55w halogens, but for HID replacing halogens, it is 35w HID for stock fogs....i am not so sure how long can your 55w 3k HID in your fogs last for cuz 55w HID generate much more heat in small area in your fogs....sometimes 55w HID might melt your housings....
Do we need to run a relay with the 55w ballasts? I don't currently run one with my 35w system, but i'm retrofitting to Acura TSX Projectors and upgrading to a 55w digital ballast and bulb (6000k). I ordered the relay harness, just-in-case, but i would rather not use it if i don't have to.
but for 35w HID kit, no need to install a relay harness just choose a slim HID ballast kit (be concered of eazy installation), standard HID ballast also work well....
i dont mean relay harness is a necessity , just as what i mentioned above: it is a security to install a relay harness cuz it can prevent 55w HID ballast overload due to high temperature, power spike, and irregular voltage...
this is a really old thread....
Pretty straight forward install. basically plug and play for most applications.
you would think, but I know a few people that have set their engine bays on fire using the cheaper wire in kits and the wiring was always the cause of the fires.
Hi,
I can assure you that our (any manufacturer) oem ballast is superior to ANY other aftermarket ballast, 35w or 55w. in term if longevity and output, oem > * , in term if warm up time, OEM always > aftermarket. hope that helps
FS[Northeast]: F/s marimoto hid ballast
03evo8racer
Jul 23, 2015 10:45 PM
LordCthulu
Jun 18, 2015 05:13 PM
bluej20
May 3, 2014 10:53 AM
