Directwire 2.0 Wiring Diagram for evo 8
Old Dec 26, 2009 | 12:19 AM
fishie36's Avatar
Does anyone have this that they could share? I am installing a viper 5901 in an 04 GSR.
Old Dec 28, 2009 | 06:09 PM
mressler12's Avatar
This should work
http://www.the12volt.com/installbay/....asp~TID~64456
Just be sure to meter everything to make sure your getting the right wire. Did you get a directed 556U for the bypass?
Old Dec 29, 2009 | 11:57 PM
fishie36's Avatar
Originally Posted by mressler12
This should work
I just ordered the bypass today... I hope it comes with good instructions because the viper guide does not show how the bypass integrates in the system.
Old Dec 30, 2009 | 11:45 PM
mressler12's Avatar
If you got the 556 it is integrated through the remote starts status output wire if i remember correctly it would be the blue/white wire on the i think 5 pin harness that has the hood pin, tach, brake, neutral safety switch, and the status output on it.
Old Dec 31, 2009 | 08:06 AM
lilman8403's Avatar
The 556u or 556uw work great however i used the bypasskit one where i didn't lose a key and it worked great. But mressler is right blue/white wire (- status output)
Old Jan 1, 2010 | 02:04 AM
fishie36's Avatar
Really? What model did you order? They don't have anything older than the 08 evo on the vehicle finder...
Old Jan 3, 2010 | 09:23 AM
mressler12's Avatar
Yes, what bypass did you use? I have only heard of using universal bypass units in which you lose a key. Let us know what you used! I want to get one too! Also, did it take 2 keys to program or just 1?
Old Jan 15, 2010 | 06:01 PM
fishie36's Avatar
Bump
Old Jan 19, 2010 | 01:19 AM
shortdahri's Avatar
Thumbs up
I used a 556u bypass for my 2003 mitsubishi evo 8 and used this car alarm wiring diagram during my install:
http://www.modifiedlife.com/2003-mit...iring-diagram/
Old Jan 20, 2010 | 05:23 PM
fishie36's Avatar
Did you have to use any relays or extra parts not included with the viper or bypass for your installation?
Old Jan 27, 2010 | 06:19 PM
fishie36's Avatar
Bump for above question.
kpt6
Apr 17, 2013 01:12 AM
zasboy
25
Oct 14, 2012 12:44 PM
