Amp or no amp?
Adding an amp is well worth it. Will make them much clearer at higher volumes.
A 5 ch will work also if you plan on doing a single 10 or 12
Be careful which amp you choose some of the 5 ch amps are garbage.
They will sound at least twice as loud, however it really depends on your head unit on how much clearer they will sound. A high end alpine with 3 preouts is obviously the best solution. But one with two would work for your set up as well. Boostwhore is right though. Most 5 channels are just big and don't perform. Best bet is to have a sub amp and aeither a 2 or 4 channel for the speakers.
Just my opinion
Just my opinion
Add an amp.
The speakers are rated for 10-100 watts RMS and at most your head unit probably only puts about about 22 watts RMS at the most. When you turn your volume up higher and the radio peaks out at the 22 watts RMS, the Polks will start to get distorted and from here you will start damaging your speakers. By under powering speakers, they are at higher risk of blowing than being over powered.
And since you want a sub, depending on how much bass you want, you can run one amp. I have a 6 channel amp in my Evo and I bridged the last two channels to power a sub at 300 watts RMS, which is enough for me.
Yes definitely add an amp. Our cars are pretty noisy on the road especially if you have an aftermarket exhaust. Even with my amp, I'm having to turn up the volume fairly high to drown out all those wonderful Evo noises.
Truth be told, automotive forums are the only places I've ever come across in 30+ years of audio where folks simply install rear speakers as a matter of course. Why would someone go through an extended install and spend more money only to get worse sound quality? I really don't get it. Is it because there are speakers in the rear to begin with? Almost every Evo on here gets rear speakers. It's like the folks who plaster asphalt-based, useless garbage like Fatmat all over their interiors, and other copying the inane process without a clue as to its purpose.
