Broken Headlight Tabs
Old Jan 31, 2010 | 11:11 PM
rodent's Avatar
I have a perfect IX HID headlight but the mounting tabs are broken on the top. Can I take my old VIII non-HID head and swap the black housing part that the tabs connect to? This will require to take apart both lights.
Old Feb 1, 2010 | 05:30 AM
Nasty Evolution's Avatar
VIII and IX headlight assemblies are basically the same. All of the parts will interchange. The only differences you could come across would be painted parts and if you are swapping between hid and non hid assemblies. Even then the parts can be used if you don't mind doing a bit of work.
Old Feb 1, 2010 | 06:25 AM
rodent's Avatar
Thanks. I wasn't sure if it made a difference between HID and non-HID. I realize I will have to swap the chrome and black chrome which I assume is easy to swap once both heads are apart.
Old Feb 1, 2010 | 06:35 AM
mifesto's Avatar
do you still have the broken tab? you can try plastic soldering
Old Feb 1, 2010 | 07:41 AM
rodent's Avatar
I tried plastic welding it and it didn't turn out that good and I think I lost the other tab...
Old Feb 2, 2010 | 09:21 AM
rodent's Avatar
Update- HID and non-HID lights ARE different so another HID light would be needed for this repair.
Old Feb 2, 2010 | 06:37 PM
I was just going to update this also. I have in my hands a set of OEM HID and OEM non HID assemblies in front of me. I appologized for the incorrect info, I was told by someone on here who does headlight work, they were the same besides the obvious. Obviously not so at all.
Old Feb 7, 2010 | 04:22 PM
Steed77's Avatar
Might want to source a new tab and see if you can fab it on.
Something like this might work.
http://www.ecstuning.com/ES1067/
Old Feb 7, 2010 | 11:53 PM
rodent's Avatar
No problem. At least its now posted here to let others know going this route.
Yeah, that may work depending on dimensions but I'm not sure I want to take a chance with VW tabs. Really sucks.
I ended up buying a set of JDM HID lights and I sold my good IX light. Still have the broken IX light with the broken tabs.
Lukelis
Mar 23, 2017 11:27 PM
jaime8754
Mar 4, 2017 12:50 AM
badev0
Jan 17, 2017 12:20 PM
ChicagoEvo9
May 20, 2016 07:18 AM
boczo777
Jan 31, 2015 04:56 PM
