Gauges Won't work
Old Apr 24, 2010 | 11:57 PM
20austin08's Avatar
Gauges Won't work
As stated, my car was recently broken into and my cd player ripped out and stolen. Now that I have put everything back together, none of my defi gauges power on, nor do the lighs behind my tach/speedometer etc work either. Everything worked perfectly before but cant figure it out now. I checked all the fuses and I have also checked for cut wires. Any help would be appreciated. Everything else works great. my cd player included although it doesnt power on automatically i have to push the power button.
Old Apr 25, 2010 | 10:33 AM
02-Lancer-Es's Avatar
Check the fuses it sounds like that to me . I think you must have blown the illumination fuse .
GL
-Antonio
Old Apr 25, 2010 | 11:05 AM
20austin08's Avatar
hmm. i checked all the regular fuses and they were all intact
Old Apr 25, 2010 | 12:49 PM
20austin08's Avatar
-bump-
hmm anyone know what the correct order for the defi control box. two sets of wires were pulled out and i put them back in. maybe i didnt put them back in the correct spot. Also the orange wire is the wire from the defi control box. could tht be the hot wire?
Old Apr 25, 2010 | 11:30 PM
josel_atr's Avatar
im positive that its a blown fuse. check the fuses located in the fuse box in the engine bay. its the one with the yellow cover. its tricky to take the fuse out. you will need a long nose pliers.
i blew the same fuse here:
https://www.evolutionm.net/forums/ev...ights-out.html
as for power source of your gauge, i would use a fuse tap..
this is a better approach to adding a circuit (like a set of gauges) instead of tapping into an existing wire. this is the same method i used for my gauges. now my gauges are on when the car is on. (off when the car is off, duh). let me know if you need to know which slot i hooked it on to. i dont remember off the top of my head.
edit: this might help you too:
http://www.evolution-8.com/howto/defi.php#defi5
Old Apr 25, 2010 | 11:36 PM
20austin08's Avatar
yea tht would def be nice and thanks for the help. and ya someone else said somethin about the fuses in the yellow thing. i removed it and checked them all.... i will check every one of them again but i checked all teice prolly. maybe i just overlooked it... ill def check this out in the morn. I gotta do tht and try an find out which o2 sensor i need to get to replace my one with my lc-1 thts burnt out.
Old Apr 26, 2010 | 01:26 PM
20austin08's Avatar
http://www.evolution-8.com/howto/defi.php#defi5[/QUOTE]
Thank you again. i did the fuse approach and now my gauhes work except they have no illumination until i turn my headlights on. Im ok with tht tho i guess. bc for some reason my speedometer and tach are lit up all the time now and i did nothing with them. weird. also the link was helpful. i will redo the wiring to match the correct way it shows.
Old Apr 26, 2010 | 01:51 PM
josel_atr's Avatar
glad to help. enjoy playing with wires!
Old Apr 26, 2010 | 08:10 PM
YuLost2x's Avatar
I have a similar problem. The CD player wont power up by itself and also my rear tailight now doesn't work+ my heating/ac doesn't work. Any help would be appreciated. If you guys could also email me any solutions at Amusanovic@gmail.com
thank you
Old Apr 26, 2010 | 11:01 PM
20austin08's Avatar
Did u check all ur fuses?
Old Apr 27, 2010 | 11:37 AM
mump's Avatar
I am sure you already know this but just in case, some defi gauges must be plugged into output 2 on the control box.
nevermind, it says that in the link....
