Battery relocation advice
Old Aug 19, 2010 | 01:00 PM
F0RSAKEN's Avatar
I'm going to be removing my mini bat, and getting a full sized Optima relocated to the trunk here soon, but after looking through all the relocation kits, I still can't find a clean way to terminate the positive lead from the battery in the engine compartment.
Half the 'how-to's' I've seen have the leads just wired up and stashed somewhere, which IMO is not clean nor is it safe.
I'm looking for something, like a mountable block of some sort, that I can wire the positive from the battery, and the negative to chassis, to, maybe something with posts on it, so I can wire up the stock terminals to it without modification, and in the event that I need a jump, I don't have to trip people out and have them pull up behind me lol.
Ideas?
Old Aug 19, 2010 | 01:36 PM
igo4bmx's Avatar
you should use a distro block?
the downside is the stripping of the factory terminals.
Old Aug 19, 2010 | 03:10 PM
avo3vom's Avatar
I didn't want to sever any stock cables. I connected 1 gauge cable to the stock distrubution block, mounted it in a box on the firewall, and installed a 150 amp breaker in the trunk. https://www.evolutionm.net/forums/ev...ocation-2.html
Old Aug 21, 2010 | 05:51 PM
doyle4281's Avatar
He is right, be sure to install a fuse or circuit breaker.......
Old Aug 24, 2010 | 10:52 AM
w8lifter21's Avatar
Fuse > Circut Breaker
KenyonKanye
Oct 2, 2016 05:20 PM
Junkyardspecial
May 14, 2016 11:40 PM
DeFog
Sep 3, 2014 11:15 PM
amscrazy
Jan 30, 2008 11:33 AM
propellerhead
Oct 15, 2004 07:23 PM
