anti theft
Old Jan 4, 2011 | 08:16 AM
Alexl08's Avatar
anti theft
So alot of cars in my area have been stolen lately mostly turbo imports. I dont want a fancy alarm system tho because they get to be a pain in the but. My idea is to run a tiny push button switch under the truck release handle and basically make this the clutch switch so in order to start this will have to be depressed. I know this would stop the hard core thief but i dont believe thats what we are dealing with. Has any one done this how did it work out for you?
Old Jan 5, 2011 | 02:03 PM
hboy7777's Avatar
yeah, ive done it on a few cars. works very well. you can also use a switch to cut power to the main relay so they cant just jump your starter
Old Jan 14, 2011 | 10:10 PM
MRGEVO's Avatar
I have done some minor mods to my car. I have hidden pull/push type Kill-switches that cut power to the ecu, and fuel pump. I also have an alarm and steering lock + the car sleeps by my room. A bit of over kill.
Old Jan 14, 2011 | 10:29 PM
joseph143's Avatar
if you wanna do something simple yet fancy... rerun your starter relay power wire back inside the cabin... use a high power on off switch like a battery kill switch... then run the wire back to the starter... there is a steel bracket behind the dash light dimmer that is rugged enough to support it but still be hidden... mount it there and viola! you have a nifty kill switch that will allow you to maint power to everything but wont start the car unlike a battery kill switch... and if you trip it while driving youd never notice unlike a fuel pump or ecu kill switch... i'm sure there are other ways... but i'm the best so use my idea...
Old Jan 15, 2011 | 04:36 PM
MRGEVO's Avatar
well, now we know where your one is! I know when mine is off or on coz the check engine light tells me. If you know what you are doing a kill switch is way less work than what you described. All you do is cut the line, put the switch in and mount the switch.
WickedMRsiNY
Sep 17, 2010 11:35 AM
bronto11588
Sep 8, 2010 02:39 PM
06ravenmr
AEM EMS
Oct 29, 2009 01:57 PM
wizzo 8
Feb 10, 2008 06:45 PM
blakevo8
Feb 22, 2007 04:51 PM
