My tail light problem
Old Jun 26, 2011 | 01:31 PM
Joshs EVO's Avatar
So I have had this problem for a few yrs now. My driver side tail light is out. It's just the running light, not the brake light or the turn signal. The tail light works when I swap it over to the passenger side so it's not the bulb or the tail light assembly.
I've checked the fuses and they are fine but just to be sure I removed the used ones and placed new ones in and still nothing. There are no bent pins in the connectors except some are loose. Shouldn't be a big deal cause I can swap it over to the passenger side and with the loose connectors it works fine.
Anyone else have an idea of what this could be?
Old Jun 26, 2011 | 02:38 PM
Joshs EVO's Avatar
Found the problem. It was a loose connector under the dash board. It was hard to tell but I traced the green w/yellow wire to that connector and while I was checking it it wiggled so I knew it was loose. I was like. Nah it can't be that easy. But it was.....this time.
Old Jul 11, 2011 | 08:18 AM
dakrush's Avatar
thank you for updating this thread with your solution. I have the same problem and i am going to double check that connection.
dailydriven09
Lancer Troubleshooting
10
Oct 21, 2014 07:35 PM
Reba
Jul 23, 2012 06:16 AM
maxims4g63
May 27, 2012 10:57 AM
sillypuddy
Canadian Forum
11
Apr 14, 2011 09:03 AM
shuttlegoose
Oct 2, 2008 05:40 PM
