Android + Evo
Old Apr 5, 2012 | 10:50 AM
  #61
delito's Avatar
Originally Posted by stabiemcstabin
Quick off question I don't know much bout stereo but would this work for my android to play music through my speakers? Android to 3.5 to jack to rca to (this is what I curious about) http://www.bestbuy.com/site/Scosche+...3#BVRRWidgetID to metra harness to stereo harness ?
Should do, but this directly to the AUX RCA input (rear of stereo) would be plug and play.
http://www.flatheadenterprises.com/w...ca_to_mini.jpg
Old Oct 14, 2012 | 06:55 AM
  #62
rsonistxl's Avatar
do you need a wifi galaxy tab or does it have to have 3g?
Old Oct 18, 2012 | 12:26 PM
  #63
kyoo's Avatar
another option..
http://www.engadget.com/2012/10/04/p...inment-system/
Old Nov 12, 2012 | 02:13 PM
  #64
geminibby's Avatar
bump for light reading later. Good pics!!!
Old Nov 19, 2012 | 06:43 AM
  #65
funyun's Avatar
Wow thats badass never even though of that before. Looks like a real clean setup too.
Old Nov 23, 2012 | 06:54 PM
  #66
TigOLDBiTTies's Avatar
im curious why you dont just have the tablet >3.5 to rca> AMP> speakers??
why do u need a metra harness and stereo harness?
Old Nov 25, 2012 | 10:17 PM
  #67
the_evodude's Avatar
damn this looks sick
Old Dec 6, 2012 | 07:26 AM
  #68
600RR's Avatar
I'll take a guess at this. So he doesn't have to run wires from the amp back to the speakers. It would be easier to just intercept the speaker wires at the radio harness. Otherwise you're going to have to dig through the wires coming from the door to find the speaker wires and intercept them there. That can be a pain. I did this kind of stuff for a while years ago.
I'm gathering my info for doing this soon. I will probably use a Google Nexus 7. I have a rooted Tbolt with wifi hotspot I'll be using for connection. I mainly want to use a Nexus 7 b/c the softkeys are actually on the screen. So when you turn the tablet sideways to put it in the car they are at the bottom instead of the right side. Trivial, I know, but I'm ****.
OP, I'd like to know a couple of things please
1-Which tablet do you use specifically? I'm wondering about fitment since I'll be using a different tablet, but your fitment is exactly what I want.
2-How is the audio? Do you have any ground loop noise? I've read this complaint.
3-Why didn't you use a volume knob? I plan on using one for ease, but is the onscreen volume control easy to use? I can be talked into this option. I just figured it would be easier to have a knob.
4-Have you done anything for power control? I'd like to have it shut off when I turn the car off and turn on when the ignition is on. I thought there maybe a power control app that allows you to have the tablet set to On when charging, Off when not charging.
5-I'd like to use it as an mp3 player. I would be getting music from the internal memory. In order to put new music on it I'd have to be able to get to the tablet. I can't think of an easy way to do this. Maybe make the tablet just fit snuggly so it will not fall out, yet I can pull it out to pull the tablet and put new music on it. Or.....use a cloud drive? I really don't want to rely on an internet connection just in case my phone doesn't have one. I'm still researching this. Maybe some kind of air sync.
Old Dec 14, 2012 | 11:17 PM
  #69
ito6162's Avatar
i'm liking this option better than the ipad one. Good work!
I only skimmed through the tread but will you be planning to connect your phone to it wirelessly?
Old Dec 14, 2012 | 11:26 PM
  #70
tdt1805's Avatar
Looks awesome but a lot of work I feel.
Old Feb 16, 2013 | 06:54 PM
  #71
rasssta's Avatar
Been thinking of doing this for quite a while and this thread made me decide to go for it
How did you wire the Tab in for power?
How did you re-configure the magnify button for sleep?
Old Feb 17, 2013 | 08:45 AM
  #72
kyoo's Avatar
The fact that a lot of tabs now have wireless + data plans for a lot of phone companies are just add on device w/ shared data, i think the idea is much more reasonable. All you need is a power solution and music/stereo solution, so connectivity is really the only issue..
If someone sold a kit for all that it would be amazing
Old Feb 18, 2013 | 03:57 AM
  #73
rasssta's Avatar
Also, which theme are you using? Looks awesome, and I want it. But I haven't been able to find it
Old Feb 18, 2013 | 09:08 AM
  #74
l2r99gst's Avatar
Originally Posted by unsungboxer
Newest version of torque pro has option to use maf to determine boost instead of the usdm map sensor that maxxesout at 3.1 psi. Seems more accurate. My screenshot from months ago was due to me messing around with the boost calculation which is why it was so wrong. Not sure what my pid speeds are but i use the cheap ebay elm 327 with reasonableresponse speeds. Make sure you are using the torque setting that speeds up obd.
One last thought, torque pro works way better than torque lite. Make sure you all use the paid version.
I haven't used Torque yet, as I have had a CarPC for years as well, with EvoScan, DMA, etc, etc.
But, from what I hear, Torque will allow you to log MUT (over OBD) so you can input whatever you want to log from MUT (ie your particular map sensor) and put in the appropriate formula, etc.
As long as you know how to update your MUT table for which request you want to log (check ECUFlash forum), you should be set to go.
Old Feb 18, 2013 | 08:53 PM
  #75
STy's Avatar
STy
I agree, it would definatley sell quite a few units. I would get one when I get an Evo.
Torqued is an awesome app, I've used it a few times on my car and it works pretty well. I like what you've done OP, keep up the good work.
