Best Place to Wire Defi's
Old Oct 16, 2012 | 04:44 PM
06MRV8Killer's Avatar
Cliff notes - Need to know the best connection points for wiring Defi's
So I had someone who was once very active on the forum wire my Defi's in my dash with a Gruppe-s pod to hold them.
They are 60mm Imperial (Blackout face) boost, EGT, and OP gauges along with the controller and something is up with them because they kept turning off and I would jiggle the controller and they would come back on...
Anyways, I did a 6 to 5 spd swap and the problem was even worse afterwards and now they wont turn on at all so I have the pleasure of pulling everything apart and will probably find a complete crap initial wiring job and I will do everything correctly as its what winds up happening with every car I own. I pay someone to do it for me expecting them to treat it and wire it like their own and it turns out to be completely half assed....
Anyways. Sorry for the rant but i need to know the best places to run the wiring for these so I dont wind up toasting the battery. Any help would be greatly appreciated.
Old Oct 16, 2012 | 04:52 PM
ak47po's Avatar
I wired mine this way no probs for six years.
https://www.evolutionm.net/features/...4&pagenumber=3
Old Oct 16, 2012 | 05:15 PM
Thanks, is that just for the control unit or the gauges as well? Or does only the controller get wired in and the gauges run off the controller?? I dont know this info, its been a long time and I wasnt there when the guy did it
Old Oct 16, 2012 | 05:16 PM
BTW, are the pics in that link working for you or anyone else? They arent for me...
Old Oct 16, 2012 | 05:20 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Not sure I understand your question?
Here are some links that might help get you started:
https://www.evolutionm.net/features/printpage.php?id=45
http://www.evomoto.com/tech_info.php...f01382daaaf239
Old Oct 16, 2012 | 05:23 PM
Thanks Golgo. Sorry let try asking this. Do the gauges light up and run off of the controller or are they also wired separately as well?
Old Oct 16, 2012 | 05:27 PM
ak47po's Avatar
Theres three pages to the article.
https://www.evolutionm.net/features/...4&pagenumber=1
Old Oct 16, 2012 | 05:46 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
I would say locate the controller and follow the power wire to the source and the ground. If it's using an Add-a-circuit it might be simply loose.
Old Oct 27, 2012 | 10:26 PM
fafaforza's Avatar
If your gauges work fine, but they cut out, then most likely the connectors are loose.
I'd simply go through all of them, and redo/replace them. Crimp them properly, get a 40 watt soldering iron and solder all connectors with their wires. Also, check over the wires as one of them might have gotten broken or cut from something moving behind the dash.
Old Oct 29, 2012 | 01:49 PM
Thanks, yea I think the guy who put them in just did a really half assed job
iLLevo_
16
Feb 19, 2017 09:30 AM
iLLevo_
32
Nov 21, 2016 08:02 AM
Need4Spd
Jul 18, 2009 10:56 PM
TREVORSEVOVIII
Jan 6, 2008 10:07 AM
qbbraveheart
Mar 18, 2005 08:48 AM
