Viper 5704 remote start/alarm questions
Old Jan 16, 2013 | 09:21 PM
Blue_05EVO's Avatar
I cannot find for the life of me an install for the 5704..
There are a few wires it calls for that I can't find on any diagrams I have searched for
Problem wire below: location would be appreciated
Accessory output
Accessory/starter input
Ignition 2
Starter output car side
Parking light isolation wire
Neutral safety
Oem alarm disarm
Brake shutdown input
Hood pin
Trunk pin
Oem alarm arm output
Any help is greatly appreciated
Also willing to pay to have a person install if its cheaper than audio stores do it lol
Old Jan 17, 2013 | 12:01 AM
Blue_05EVO's Avatar
Bump for wanting it installed this weekend
Old Jan 17, 2013 | 11:30 AM
Blue_05EVO's Avatar
Morning bump
Old Jan 17, 2013 | 01:51 PM
Lancerboy89's Avatar
https://www.evolutionm.net/forums/ev...g-diagram.html
try here this might help, sorry best i can do good luck
Old Jan 17, 2013 | 02:24 PM
Blue_05EVO's Avatar
Thanks I have looked at the different ones on here
But they are also missing the ones I mentioned above for the lost part
Old Jan 17, 2013 | 06:26 PM
NWEvoViii's Avatar
You might have seen this thread already but check it again, it is helpful for those who want to install their own alarm.
https://www.evolutionm.net/forums/ev...questions.html
Other than that, I'll try my best to help you.
The Accessory output wire (Heavy gauge orange wire) goes to your accessory wire on your ignition harness.
If the Accessory/starter input is on the same heavy gauge harness and if it's red or red/black or red/white, just give that wire 12v. The 12v wire is also on your ignition harness.
Ignition 2 goes to 2nd ignition on the ignition harness.
Starter output car side should be a purple wire on the heavy gauge. You have to cut the starter wire on the ignition harness and the car side wire goes to purple. Connect the green wire off the heavy gauge harness to the key side of the cut wire.
Parking light isolation wire - Cut it with about 3" from the harness and tape it off, you don't need it.
Neutral safety - Ground this wire or hook it up to the toggle switch that your alarm came with. When this wire sees ground, it allows the vehicle to start, if it doesn't see ground, your vehicle wont start.
Oem alarm disarm - Hook this up if you have a factory alarm. A good way to test if you have a factory alarm is to roll down the drivers window, lock your car and wait 30sec. After you wait, open the door from the inside and see if the horn goes off. If alarm goes off, then hook up this wire to the factory alarm disarm wire. If it doesn't go off, cut this wire short to the harness and tape it off.
Brake shutdown input - This wire goes to your brake wire.
Hood pin - You'll have to mount the hood pin switch that comes with the alarm under the hood and run a wire to it. Not many cars have a factory hood pin.
Trunk pin - You'll have to run a wire into the trunk and tag the trunk light wire.
Oem alarm arm - If you have a factory alarm, hook this wire up to the factory alarm arm wire.
Old Jan 17, 2013 | 07:15 PM
Blue_05EVO's Avatar
Awesome thanks
johnjonfenomeno
178
Jan 7, 2026 09:18 PM
pinegreen
15
Jul 25, 2014 04:28 PM
danmark
10
Dec 31, 2012 10:17 AM
johnjonfenomeno
13
Aug 11, 2008 11:20 AM
fkedke
Jun 5, 2008 12:18 PM
