Some headlight/HID help
Hey guys i have a 2005 SSL and ran into a small problem. This being my first Evo i cant just look at it and know whats going on like a DSM! I guess the PO didnt bolt down the ballast for the driverside HID... Because it fell out and was smashed to nothing by the cars behind me. Now as far as replacing it im not sure where to go. Will any HID kit work? Are they all just plug and play? I hate electrical/wiring so this is my weak spot in cars.
Thanks in advance guys. Any companys you personally recommend?
You either buy an OEM ballast so it can be re-attached to the headlight and seal the hole that it's covering, or you buy aftermarket ballasts, buy a connector / adapter thing or clip your stock one and solder on a new one, and then find a way to seal the hole in the headlight
easiest way is to buy a stock ballast from an evo
I origonally wasn't going to consider going back to OEM but after checking out some pics of how they look I don't really see a difference. Makes me question why they went aftermarket to begin with. OEM seems like the best option right now
then you don't have factory HID's; as far as i know the only hid's are ones with fog lights (which the SSL should have). get any ballast with a 9006 plug and they'll be plug-and-play
my go-to's are http://www.theretrofitsource.com/com...-ballasts.html - ballasts have a standard 9006 plug on them so for your car they should be plug-and-play
quickest way to double check this is to pull your front bumper and take one headlight off
Could be car was in an accident, could be owner wanted some extra cash when he sold the car
your car also has evo 9 headlights on it, evo 8's were the chrome housings not the dark metallic color housings
I have the factory Headlights with Foglights, is it the same for me? I can get a aftermarket ballast and just disconnect the oem and connect the aftermarket?
Yes in your case this would be the best option to run aftermarket ballasts. You could ziptie the ballasts underneath the lights for a clean install.
RuskiEvo
Oct 9, 2014 02:32 PM
Sideck
Mar 3, 2011 10:53 PM
REV.olution
Feb 25, 2010 06:50 PM
LanEvoNine
Dec 6, 2007 05:47 PM
