faster/better way to disable Evo from theft?
Old Dec 31, 2021 | 05:11 PM
asayamalaka's Avatar
Along with the rising crime here in LA, car theft is increasing as well. The other night my neighbor's car was stolen, right next to my IX. No broken glass, nothing suspicious seen or heard, just gone in the middle of the night.
As of now, I'm pulling the ignition coil fuse (#1) from the driver's side fuse box that's in front of the clutch pedal. Car turns over but won't start.
Obviously this isn't ideal, and will be a pain in the butt every time I take the car out. Is there a faster/better way to prevent thieves from starting the car and driving off?
Old Jan 1, 2022 | 10:21 AM
audiofan's Avatar
You can use valet mode from Tephra as a prevention for theft
auto valet mode on, and a limit of 500 rpm in valet mode, so It wont turn on, unless you disable valet mode (10 sec pedal to the floor before ignition)
You can also use a alt map with a injector scaling way off or rpm limit really low, so it wont turn on unless you change maps
Old Jan 1, 2022 | 12:47 PM
kyoo's Avatar
i have a viper alarm on my evo. aside from it actually sitting in the garage, i've got cameras all around my place.
Old Jan 2, 2022 | 09:19 PM
deylag's Avatar
Thieves can defeat a viper alarm. I suspect that when the disarm signal is sent to to the viper system from the fob thieves can intercept the signal and clone it to another fob. That is my rationale for how my Friend's Evo got stolen with said Viper alarm system being defeated.
Old Jan 3, 2022 | 07:14 AM
kyoo's Avatar
yea i mean ultimately you cannot stop a thief if they've got enough resources to steal the car, unfortunately.
Old Jan 3, 2022 | 07:52 AM
ViciousLSD's Avatar
you can wire a hidden switch to your clutch switch(plug). I still use a club...the one that looks like a baseball bat. A visible theft deterrent is important. Batt disconnect/E85 map switching possibly can help, the car wont get far. for towing, mayne theres a handbrake lock available
Old Jan 3, 2022 | 07:59 AM
ViciousLSD's Avatar
Old Jan 3, 2022 | 09:23 AM
Biggiesacks's Avatar
A deterrent is only as good as its install / implementation. If I can reach up under your dash and pull out the alarm brain, then you just helped me hot wire your car. Bonus points if you were dumb enough to embed the key. The Evo interior comes apart really quick too, so you're going to have to be creative.
If someone is attacking your car electronically, I think you're probably screwed. It does make a case for something as simple as a well hidden analog switch.
Modern cordless power tools can chew through stuff pretty quickly. It's crazy how fast you see dudes stealing catalytic converters.
Old Jan 3, 2022 | 10:29 AM
this is hilarious
this is genius, thank you
Old Jan 3, 2022 | 10:31 AM
ViciousLSD's Avatar
Originally Posted by asayamalaka
this is hilarious
yeah watch the thief walk away laughing. priceless!
Old Jan 3, 2022 | 03:53 PM
eliruiz's Avatar
You can try looking into the drone alarm system.it uses the compustar system. Has a remote start and valet mode in it got it on my Evo 10. I didn't even need the actual alarm remote. Cause I can just use my phone instead.
Old Jan 13, 2022 | 02:11 PM
mitsuatb's Avatar
Trunk Monkey with a tire iron
Positron
Feb 7, 2016 12:35 PM
Tagge
23
Jul 30, 2012 01:50 PM
Tfresh
Mar 11, 2011 09:13 PM
Mr. Stock
Apr 26, 2006 10:36 PM
evoloz02
Lancer Troubleshooting
Jul 18, 2004 01:03 PM
