WOW. Some tidbits.
Old Jan 6, 2005 | 09:16 AM
  #76
Terry S's Avatar
Originally Posted by davidbuschur
Thanks for the post Bob, I appreciate it. Glad to hear your happy with the car.
Yes, the alky kit will make big gains on the stock turbo also. I am going to do some testing coming up here on the RS with it actually and see what kind of power levels I can get with 94 in it and the alky.
The stock turbo can make high boost levels but they will eventually fall off as the rpm climbs. I have done a couple of these kits on the stock turbo cars and the gains were pretty crazy. You end up eliminating the retarded timing from knock, adds a bunch of the power from that, then you have the extra boost on top of that.
Installation is pretty easy. You have to install the spray nozzle in the upper i/c pipe, so a hole will have to be drilled in it. Then the wires are run inside and you have a hot and ground. The bottle replaces the factory i/c spray bottle.
David Buschur
www.buschurracing.com
David,
What about on 05's?
Thanks,
Terry S
Old Jan 6, 2005 | 09:37 AM
  #77
agolgan's Avatar
will this work on the mr? without the actual intercooler sprayer? is it possible to maybe locate it in the trunk? or maybe up front w/ small batt kit?
thanks
anthony
Old Jan 6, 2005 | 10:03 AM
  #78
justchil's Avatar
Man this sounds badass. I've only got access to 100 octane and it's 90 mile drive round trip.
