Installed Greddy Type-S BOV, have a question.
Old Oct 2, 2004 | 11:53 AM
[Cyanide]'s Avatar
Car runs great, holds boost great, idles great, all in all, car runs perfect.
I just have a question about the lower vacuum port. Should I cap it off or leave it open?
Old Oct 2, 2004 | 11:56 AM
ArchieBabes's Avatar
Mine is capped off, but I took out the cap, and nothing changed at all.
I bought mine used, and sometimes when at idle a whisle sound is coming off from the intake.
Anybody here experiencing the same situation? Also when you go 1st and 2nd and you left off sometimes you can hear a faint whisling sound.
Is that normal???
Old Oct 2, 2004 | 11:58 AM
evolucion's Avatar
I think you got the BOV on too soft. Try tighten it a bit.
Old Oct 5, 2004 | 05:04 PM
wprettyboy's Avatar
i just installed one too. i thought that it would be louder than it is. i dont here any difference. have i done something wrong. also if i cap off the port to the intake will that be the same as VTA.
some dont like it but i want the sound to be loud!!
Old Oct 5, 2004 | 05:24 PM
l2r99gst's Avatar
If you don't attach the lower nipple to a boost source like your upper IC pipe, the nipple should be left open.
No air will leak or enter through the nipple to your IC pipe. It is just an entry into a sealed chamber to help push the valve up and open the valve. If you cap the nipple, it will have a harder time expelling the little amount of air that is in there when it blows off. Hope this made some sense. If not, I will find the an old link on a DSM forum that explains and shows autocad drawings of the Type-S.
Eric
EDIT: Here is the link: Greddy Type-S with Autocad drawings
Here is one of the images from that thread to give you an idea:
I'm not sure if you have to be a member to view. If so, join, and this should answer every question about the type-s you ever had.
On a side note, from my personal experience, put some sort of thread sealant on the bolt that you use to adjust the BOV. I tested mine before with a Mityvac hand pump and it leaked at 10psi...after I sealed the threads, it held over 30, no problem.
Old Oct 5, 2004 | 05:45 PM
evo81's Avatar
^thats some great info
Old Oct 5, 2004 | 05:46 PM
wprettyboy's Avatar
Can anybody help me on this, please!!
Old Oct 6, 2004 | 01:16 PM
evolucion's Avatar
Did you install it right? if not don't expect to hear anything. If you did install it right, then just try to loosen it up a bit. Well to the point where you can here it of course. good luck!!!
Old Oct 6, 2004 | 01:18 PM
wprettyboy's Avatar
i figured it out. made some mod changes and now it is loud. it is very close to VTA and holding boost all the way to 20.5 (will hold more but that's all i need for now)
Old Oct 6, 2004 | 01:49 PM
4G63 Racer's Avatar
JUst leave it open its really for high horse power cars, Its to help push the valve open but you will never need it like that. And do not VTA your cars mas air reads off of that, who care if its loud, as long as it holds right?? go stealth.
grnkronic20
Apr 21, 2015 07:30 AM
FearDavid0586
Evo X Dyno Results
14
Jun 21, 2013 11:20 AM
ouminan
15
Aug 23, 2006 03:03 AM
rlazer5000
Oct 19, 2005 05:49 AM
EvoBoy03
Oct 31, 2003 02:54 PM
