Got Walbro Pump...Do i need a Fuel Pressure Regulator?
Old Oct 8, 2004 | 09:14 AM
EvoRs's Avatar
I bought the 255 Fuel Pump.. will i need a fuel pressure regulator or will my flash adjust enough to handle this with the stock one. I will get a turbo kit in the future.. should i just upgrade it then?
thanks
Old Oct 8, 2004 | 09:21 AM
snoop's Avatar
thanks
I put mine in my car when it was tunned. I have an exede. Until you have your ecu tunned then you don't need it iinstalled.
2k4EvoVIII's Avatar
thanks
I would just get it when you do the turbo. Stock is actually pretty good i have had no problems when i hit the 500whp mark but now that im looking at 650whp im starting to see some problems.
Chris
Old Oct 8, 2004 | 09:33 AM
Ted B's Avatar
You shouldn't need anything but the factory FPR, although there is no real reason to install the 255lph pump until you are ready to install the turbo kit and calibrate the entire package.
Old Oct 8, 2004 | 09:38 AM
snoop's Avatar
Very informative Fuel Pump Sticky from VISHNU. When you are no longer stock you should get the fuel pump especially with more agressive tunning.
https://www.evolutionm.net/forums/sh...ad.php?t=56001
Old Oct 8, 2004 | 10:00 AM
EvoRs's Avatar
Hmm. well im doing Cams, 264/272, pump.. and flash.. so i wasnt sure if the FPR would be something i should look into .. but from what i hear.. i shouldnt need it till i get a turbo kit..
Old Oct 8, 2004 | 10:11 AM
EvoRs's Avatar
Can i put the Walbro Pump in without a tune.. Im going to be doing the Cams and Pump.. and then the tune.. Should my car be safe to drive a few hundred miles before i get the tune.. should the car run fine until then?
Old Oct 8, 2004 | 10:40 AM
jong's Avatar
I asked the same question a few days ago, and the concensus seems to be that the car will run fine with the pump and no tune. That being said, I guess it will runa little richer and so you should get it tuned. So like in my case, I'm going to install it right before I leave to go get my EMS installed.
Old Oct 8, 2004 | 11:15 AM
wangspeed's Avatar
I run a walbro, xede, turbo back, and gears. I didn't mess with the baseline map. Only seeing 11 A:F by redline, so I'm not any richer than before. Dunno why some people are claiming it makes it too rich.
Warren
Old Oct 8, 2004 | 11:27 AM
2k4EvoVIII's Avatar
Warren
It shouldnt make anything richer at all. The fuel flow is controller by the fuel pressure regulator so it really doesnt matter what the fuel pump is pushing out.
Chris
Old Oct 8, 2004 | 11:28 AM
jong's Avatar
I stand corrected. Sorry for any confusion.
Old Oct 8, 2004 | 12:11 PM
SinCityEvo's Avatar
I had a noticible change when I installed mine before the tune. The car idled very rough and high and just did not feel smooth. Once tuned, it felt nice and idled normally.
The Walbro will make you run rich when in boost if you are not tuned for it. It felt like it lost power up top before the tune.
Old Oct 8, 2004 | 01:09 PM
EvoRs's Avatar
How difficult was the pump to install?? and where is it located.. im assuming ill be ok with a pump and cams with no tune for a few hundred mile trip before it gets tuned
Old Oct 8, 2004 | 01:21 PM
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
It is under the back seat and is not too difficult to do.
Old Oct 8, 2004 | 01:22 PM
Hatorade's Avatar
I think you may be confusing the pump with injectors, with regard to running rich.
