two bad codes thrown... please read!!
Old Oct 15, 2004 | 10:34 PM
rt turbo's Avatar
Originally Posted by Nad1370
Ummm... Maybe you installed the Cam Position sensor 180 degrees off.
If it is, the sensor is giving an advance reading to the ecu. You can idle but in higher rpm's, there is so much timing seen that the ecu will pull it back hence the studder your talking about.
Just a thought.
ive driven the car for 20,000 miles with no problem.
Old Oct 16, 2004 | 08:51 AM
Nad1370's Avatar
Sorry about that. I thought you just had your cams installed.
I would check the cam dowel pins. Maybe one of the dowel pins sunk in therefore rotating the cam slightly and not the gear so it still looks like your on time.
Just take the 17 mm cam bolt out and check if it is still lined up.
I read somewhere in here that HKS cam dowels sink in easily.
Old Oct 16, 2004 | 05:04 PM
rt turbo's Avatar
ok, this is really weird, but it went away!!?? i dunno, im still weiry about it, but i tried to make it do it and it just would not. maybe i had bad gas causing large amounts of intermittent knock and retarding my timing throwing those 2 codes? i did change the gas yesterday and didnt drive it until now so maybe i ave better gas in it now. any ideas? or its a short somewhere and its working now? but whatever it is the car is pulling hard as hell as ussual and i get absolutly no studder at wot.
Arnaldo
Mitsubishi TC-SST Discussion
Oct 16, 2015 06:59 PM
AlexEvo6
Jun 13, 2010 12:18 PM
And
May 14, 2010 11:13 AM
Y.O.EVO8
Mar 30, 2010 03:40 PM
kanyonkid
14
May 29, 2008 09:21 PM
