Does anyone have RC injectors with aftermarket or specifically VR fuel rail?
Old Oct 22, 2004 | 06:48 PM
TampaTurbo's Avatar
Angry Does anyone have RC injectors with aftermarket or specifically VR fuel rail?
OK, I went to do the install and did everything I was supposed to, Took everything apart and now its time to reassemble. Well I was having a hard time for these RC injectors to seat. I am using the same rubber inserts that came off the bottom of the stockers. Assuming I need to. Anyway, fighting and fighting to get everything to bolt down. The fuel rail would just not seat back to the original location. Everything was on the best that it could be. Anyway, then I noticed this huge gap that wouldnt allow me to bolt the fuel rail to the gold hardware to the mounting area the way it was stock. Then I had to find spacers that I could fit in between so there wasnt tthis bolt stretching between the fuel rail and mount section. Anyway, the spacers solved that problem. Thanks Vivid for an instruction manual or any possible porblems. BTW, are the injectors supposed to rotate fairly easily while mounted to the fuel rail and motor? I used a little WD to keep things smooth. Then after everything was done I realized there is this big *** hole on the top of the fuel rail. WTF is that. Well guess what? There was no bolt with the fuel rail to plug it with and now I have to go to a hardware store and try to guess what size I need to plug it. Thanks Vivid. I normally would say good thing and I would like to resolve this problem, howver I am being tuned tommorrow and unless they want to drive to my house and put it on for me then fine. Otherwise theres no use. Sorry, to be ranting. ANy help would be appreciated.
Old Oct 22, 2004 | 07:22 PM
TampaTurbo's Avatar
bump anyone?
Old Oct 22, 2004 | 08:43 PM
mttam510's Avatar
I just installed my Vivid Agency Power rail and it was sweet, no problems at all, noticed the 1/8 NPT hole, which is awesome cuz I put me a pressure gauge in der. I will post a pic. Thanks Dan, Great product! The spacers are there on the factory rail, they must have fallen from your view, the rail goes on exactly as the factory rail does, all other fittings are the same.
Old Oct 23, 2004 | 07:04 AM
TampaTurbo's Avatar
do you have a pic?
Old Oct 23, 2004 | 07:07 AM
TampaTurbo's Avatar
Didi you fuel rail come with this 1/8npt pipe fitting?
This fuel rail came wound up with paper and tape.
Old Oct 23, 2004 | 07:22 AM
TampaTurbo's Avatar
I lokked and ooked and looked and cannot find the spacers you said that are on there stock. That should have fallen to the floor becasue they are not on the undertray. It sure would be a coincidence if they both got lodged on something.
Old Oct 23, 2004 | 09:14 AM
bishiboy's Avatar
I had the same problem with spacing with PTE injectors on the stock rail. I used a couple washers for spacers, problem solved.
I also never saw any stock spacers.
Old Oct 23, 2004 | 11:02 AM
w2pac12345's Avatar
the spacers are there.
Old Oct 24, 2004 | 10:37 PM
mttam510's Avatar
spacers are there for sure....nope, no additional fittings with the rail, no biggie, a simple 1/8 NPT plug or as I did...90 degree 1/8 NPT M/F adapter..........wooo woo thanks again Dan!
Old Oct 25, 2004 | 10:10 AM
TampaTurbo's Avatar
your fuel rail does not look anything like mine.
Old Oct 25, 2004 | 01:08 PM
mttam510's Avatar
I didn't notice any other rails on the Vivid site, besides the Perrin, which is very similar....
Old Oct 25, 2004 | 01:18 PM
mttam510's Avatar
I just checked....Agency Power and Perrin are the two rails that Vivid offers, and I can speak for the AP...it worked a treat! I omited the factory return and ran one length of hose for the return from the FPR. You can't really see the port in my picture, but it is there and a nice option.
dude
84
Dec 22, 2014 04:38 PM
evopowned
Feb 7, 2011 07:22 AM
Evo8Emperor
Oct 11, 2007 03:09 PM
Evo8Emperor
Oct 11, 2007 01:23 PM
hawaiian_evo
May 19, 2007 05:02 PM
