NX Ntercooler
Old Oct 24, 2004 | 10:53 PM
EVILbtownEVO's Avatar
Question NX Ntercooler
You guys are prolly gonna get pissy for me bringing this up but curiousity is killing me. I was on Machevo.com and I saw that they said the NX Ntercooler gave them something like 48.3 more hp when running CO2 in the bottle. Has anyone put this on their Evo? I also did try and search for this topic but I could not find anything!! Thanks for the help.
Old Oct 25, 2004 | 02:20 AM
trinydex's Avatar
you can't run it forever... even the biggest tank of c02 won't last a day..., it's more for drag racing.
Old Oct 25, 2004 | 06:29 AM
yycools's Avatar
yes, I know for a fact that Al from Dynoflash has it on his car, give him +50whp when he dynoed
Old Oct 25, 2004 | 10:31 AM
cant you rig it so that you can turn it on and off, only run it when you want??
Old Oct 25, 2004 | 10:47 AM
90GSX-03EVO's Avatar
Yes.
You arm it (turn the system on), then you spray it. You can rig it up so that it is only armed when you are at the track, and only spraying when it is armed and you are at wide open throttle and at a certain RPM, you can wire it so that it only sprays when you are in gear, you can wire it so that it sprays when you are pressing over a certain PSI. Of course, all of those things will need additional switches and relays, but it can be done. I know for a fact, though, that it somes with an arming switch and a spray switch/button.
Hope this helps.
Old Oct 25, 2004 | 10:49 AM
hey guys thanks for the tips, i appreciate it!! this mod is sure gonna help!! damn sti's im gonna smash my friend now.. haha
Old Oct 25, 2004 | 10:52 AM
EVOlunchbox's Avatar
go get'em!
Old Oct 25, 2004 | 11:03 AM
You weren't beating STi's before?
Also, I'm not trying to talk bad about this product, but think about it first.
On a dyno, the car is sitting still. Nitrous comes out and evaps over the FMIC/Nitrous gets ingested into the car's intake/Nitrous enters the combustion chamber. More power is made.
On the track, the car is moving. Nitrous comes out and evaps over the FMIC/Nitrous gets sucked back under the car.
Is this acurate? Who knows. I have never done the testing, and dyno's have big *** cooling fans that probably do a good job of simulating the car's forward movement when drag racing, but still. I would ask for this to be dyno'ed on both N2O and CO2. Mach V only posted results of an N2O fill, and then recommended that you fill it with CO2, for cost effectiveness.
Once again, it might be good, it might be bad. This is one of those products that I have not personally tested yet.
Old Oct 25, 2004 | 01:52 PM
Cash Money's Avatar
one thing i wonder about... if a bit of that power comes from N2O being ingested, CO2 wouldn't be a good alternative... CO2 has an ability to rob power...
but all in all... all I've read on this, I'm going with this NX kit myself......
Old Oct 25, 2004 | 08:11 PM
Mach V Dan's Avatar
Here's my original post on my results at the dyno. I used nitrous in the bottle, not CO2. I did not retest with CO2 in the bottle, so I can't give a direct comparison. The coldness would be the same, but as mentioned, CO2 is a combustion inhibitor, whereas N2O is a combustion facilitator. I'd basically say using CO2 would be fine if your intake is sealed off or unlikely to injest the gas. Stock intake would be fine. But if you have an open element filter down low, I would advise against CO2. Drawing CO2 into your intake would be bad for power.
Results might not be the same at the track or on a public road; obviously a dyno is not the same as a road or a track. I have had anecdotal reports that the N-Tercooler is very effective at the drag strip, but no hard numbers.
--Dan
Mach V
MachEVO.com
EVOVIIIChic
Feb 20, 2006 12:47 PM
Mach V Dan
41
Apr 1, 2004 06:41 AM
DynoFlash
34
Nov 10, 2003 10:16 AM
TOMEI EVO 7
Sep 14, 2003 10:51 AM
