How much boost can the Type S BOV hold??
Ok, my Type S does that nifty flutter right, but it does it as I'm accelerating basically feels like it can't hold the boost. I've tried tightening and loosening, but nothing seems to work, I go full throttle and the car doesn't.
What do ya'll think...I don't have a lot of mods yet, a few bolt ons, 3" Invidia TBE with test pipe, ARC intake, Profec B EBC, NX Ntercooler sprayer, and Greddy Type S BOV....running 16lbs on low, 22 on high boost. Why does the BOV do that and how can I fix it or do I just need a different one? There are no vacuum leaks and everything was checked and double checked. Thanks!!
Then again, I'm an Evo n00b, so everything I say can pretty much be chalked up to conjecture and B.S. at this point.
-Bis
are you using both ports on the BOV?? the two smaller ports?? that seemed to cure my problem of leaking that little bit. the top port should go to a boost source, while the bottom port should go to a non boosted source.
Chris@nolimitmotors
447
Dec 26, 2018 04:09 PM
k270kmh
Sep 28, 2004 08:35 PM
lil'evil_evo
Sep 5, 2004 12:59 PM
hel_if_ino
13
Aug 20, 2003 04:57 PM
